586,762 active members*
7,802 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Custom milling on Aluminum
    Apr 2011
    Hey guys,
    This is my first post, so be gentle
    I dont know a lot about machining so i need some advice please.
    I have a block of metal (aluminum) i want to have cut down to some exact specs. It will includes very detailed scrollwork (etchings).
    I am unsure how to do this. I called a waterjet company and he said they could only make straight cuts and not do any engravings with it. He said to use a saw then polish it down. Then maybe have a laser for engraving? Is this correct?
    I am trying to make a prototype of thehead part Thor movie hammer. I will be through with the 3D Cad file today with all the specs. I am attaching a few photos to give you an idea of what i am trying to do with an 8.5"x5.5"x5" block. It already has basic dimensions of what i want. One of the photos show detail work on side engraving.
    Thanks for any assistance.
    Attached Thumbnails Attached Thumbnails 2dhammer.jpg   Drawing_Rev3.jpg   hammercad2.bmp
    Jan 2007
    1389
    any 3 axis cnc mill should do what you need just fine. as far as the scroll work again you need a 3 axis mill and a decent cad cam program. the engraving on the top same thing 3 axis mill.
  1. CNC recommendations for milling custom stainless steel guitar hardware?
    By Corvus in forum Musical Instrument Design and Construction
    Last Post: 03-26-2011, 12:20 AM
  2. Custom built .063" aluminum sheet polisher.
    By diyengineer in forum Mass finishing equipment/media/strategies
    Last Post: 05-04-2010, 01:56 PM
  3. Replies: 17
    Last Post: 01-15-2010, 09:52 PM
  4. RFQ - Aluminum Milling
    By Axiom in forum Employment Opportunity
    Last Post: 03-06-2007, 05:29 AM
  5. Anyone want to do some custom Milling work??
    By mrbaseball in forum Commercial CNC Wood Routers
    Last Post: 10-21-2005, 11:33 PM
