586,913 active members*
3,040 visitors online*
IndustryArena Forum > CAM Software > Vectric > Post Processors > Making sharp corners in VCarve 3.1
Results 1 to 7 of 7
    Mar 2007
    113
    I hope this is the place where I need to be
    I am trying to make SHARP corners in Vcarve 3.1
    The only way I could get it done is to make an inset line and use the "V-Carve / Engraving tool-path" Tool but this takes way to long and I would like to get a better tool path so it only cuts what I need
    The Picture is what I am look for or what the cut should look like or anything like that just as long as the corner is sharp or to a point. I also have Alibre CAD and Cam software if anybody uses that software. The design is a square and a triangle very basic. Any help would be great because My brain has been disengaged.
    Trell
    Mar 2007
    113
    The wood is .75 thick
    Aug 2005
    597
    Hello Trell,
    If you can post your file as an attachment I'll take a look.
    Tony
    Apr 2003
    312
    OK... re-read the post and I see what you're wanting... my reference to CV issue is not YOUR problem... sorry
    Senna
    aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
    Mar 2007
    113
    Here is the file
    I did get the sharp corners on a cut but had to rewright the Gcode with word pad so it would work with out have a hour cut time
    Still..... it is a pain
    Attached Files Attached Files
    Draw the inside and outside borders, and V-Carve between them.
    Mar 2007
    113
    OK I cut the test panels like the pictures, and my customer wants to cut them straight with a sharp point in the corner, I had some panels cut with a laser and they looked awesome but the wood was burnt on the edges. I was thinking about a water jet but I don't know how sharp the corners could be. I may even cut some with a CNC if I can make the corners sharp.
    What do you guys think I should do
    Trell
  1. Sharp corners
    By renato13 in forum Fanuc
    Last Post: 08-28-2009, 02:51 PM
  2. Replies: 46
    Last Post: 11-25-2008, 02:01 PM
  3. Sign making with K2CNC and VCarve Pro
    By Mike Stevenson in forum K2CNC
    Last Post: 05-06-2008, 02:55 AM
  4. Sharp internal corners
    By Sanghera in forum Uncategorised CAM Discussion
    Last Post: 03-30-2006, 09:46 PM
  5. Making a sharp inside corner?
    By Docmani in forum MetalWork Discussion
    Last Post: 11-14-2005, 06:26 PM
