Hi All,
So I have completed setting up the hardware for my new controller.
I am now having issues communicating with the encoders/motors.
I double checked every connection and everything appeared correct.
I checked each driver via USB connection and found this using the Servoconfigurator3 software:
X Axis Whale 3 Drive:
This appears to be close to functional. When I analyze through Servoconfig, I get the "Current limiting" indication on both diagnostics and the LED on the driver.
How Do I fix the current limiting issues?
_______________________________
Y Axis Whale 3 Drive seems to be the larger problem.
This one does not seem to want to do anything.
It will initially "connect to device", but when I try to use the "analyse" button, I get errors. (see attached pics) Running/fault, Servo limit reached, Error output. LEDs on wahle= 5,6 error limit override. Then it indicates "drive not answering, drive not loaded" and cannot regain connection with "try to connect button."
I get the exact same results if I switch the RJ45 connectors from the Xaxis drive to the this Y axis drive.
Sorry, I am new to this and learning as I go.
Any help would TRULY BE APPRECIATED!!!!!!
Thank you,
Greg
