I am having problems selecting 4 holes from a IGES model I imported in order to create toolpaths for a drilling operation.
The holes in question happen to be half on a ledge, and half off the ledge - the ledge being 0.050" high. If I zoom in and select all the individual segments that make up the hole (including the bits that rise up the ledge) I get nothing in the geometry selection dialog.
If I drag select around an individual hole, I get the hole which happens to be 0.070" in dia, but I also get another hole of dia .125 which does not exist. When I do this and complete the dialog, and run verification it drills my 0.070 holes as it should but then it drills a .125" hole just inside all four holes. By inside I don't mean concentric, I mean offset toward the center of the part.
By the way, I did the Extract Edges from Solid function on the part before doing the drilling operation.
How is one supposed to select geometry from a 3D part? This specific issue with the holes is just the tip of the iceberg. I am having problems selecting other profiles and things on this part as well. But I figure if I can just solve one problem at a time.... This is really driving me crazy. I've spent hours trying to do this only to give up and go to 2D drawings. But this must be possible, otherwise 3D geometry is just useless!
