586,299 active members*
3,916 visitors online*
Results 1 to 14 of 14
    Aug 2008
    24
    Vacuum Table Question
    I am trying to build a vacuum table. I have the grid cut out and will be using an adhesive type gasket around the outside, but what I am trying to decide is how to finish up the project. On the left is one way where I would connect the lines up to where the vacuum hose would enter. On the right is hollowing out the entire area (both top and bottom) which I would think it would give more air flow. Again, after I cut these areas out, I would put a top on it to seal the air flow.
    Any suggestions?
    Anthony
    Jun 2010
    check out my instructable of a small vaccum table for my cnc machine.
    Vacuum Table for Mini CNC Milling Machine
    Hopefully this can help with yours
    Cheers,
    A machine is only as accurate as the tools used to build it. "CNC = Computer Numeric Control - or on some days - CNC = Can Not Control" Imagineering
    Aug 2008
    24
    Quote Originally Posted by AssassinXCV View Post
    A little more than what I was looking for. I just want to put a sheet of MDF on top of the grid I already made and have the air travel through all of the channels. Just don't know what I should do about the top. Either use lines from each of the channels to lead to the vacuum or cut a "cave" or a large section out (triangle) that would have the vacuum on it.
    Anyone ever do this?
    Jun 2010
    Maybe use some peg board? will save time with not needing to drill the holes yourself.
    Aug 2008
    24
    Well actually you use MDF... Just take a skin off the top, flip it over and do it again. Seal the MDF to the vacuum table with a gasket all the way around and then secure them both down on the machine. Turn your vac on and away you go.
    Jun 2010
    Guess i'll have to do some research on vacuum tables, never heard of that trick; i'm guessing that mdf lets air pass through it's fibres.
    Ideally, you'd want to draw from the center of the table, with the diameter of the port the same as you're vacuum line. When pulling from one end, you'll have more vacuum at that end, due to leakage.
    Aug 2008
    24
    Dead on with that reply, however I have a Camaster Stinger (2'X3' table) and don't have room for it. That is the only reason I am going from the end.
    @assassin- That is correct, the air will flow through the MDF. If you use a peg board, too much of the air is lost and the suction down onto the table will not be that strong.
    Aug 2008
    409
    what sort of vacuum pump are you going to use for this table?
    Apr 2005
    1268
    Hey Guys;
    I've built a vacuum table for my router and my top (spoil board) layer was not MDF but LDF or low density fiberboard. Works great but I'm about due to replace it. My problem is that I cannot find a vendor and I don't remember where I purchased it. Can anyone help???
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Aug 2008
    24
    due to the fact the table is so small, all I am going to use is a 5 horsepower shop vac
    Apr 2007
    663
    Seal edges of MDF
    To make your setup work better, seal the edges of the MDF very well. Any high solids paint or varnish should do the job.
    Aug 2008
    24
    Quote Originally Posted by zool View Post
    NICE!!! Didn't even think about doing that... Thanks
    Aug 2008
    409
    I use a 2'x4' vacuum table on my machine, i made it from 1" HDPE and routered out a grid pattern that my gasket material goes in.
    I had no luck using a shopvac as a good hold down, and it sounds like you want to use a vacuum table along with a bleed through spoil board, I doubt you will have enough vacuum pressure to hold your work.
    I use 3 thompson vacuum pumps in parallel and have 6 zones. With all 3 pumps (3hp each) I get about 15"HG and about 15cfm, if I have no leaks i can pull around 22" HG. I only use well sealed gasketed spoil boards or no spoil board on parts i dont cut through, I wouldnt be able to use a bleed through spoil board as I dont have enough CFM.
    Also, your shopvac may say 5HP but if it plugs into a regular 15A plug its probably only 1-2HP.
    good luck with your vacuum build!
  1. Vacuum Table
    By CNCRob in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-19-2014, 02:38 AM
  2. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  3. vacuum table question
    By ironman014 in forum DIY CNC Router Table Machines
    Last Post: 12-29-2009, 08:23 AM
  4. yet another vacuum table question....
    By boomerize in forum DIY CNC Router Table Machines
    Last Post: 08-18-2009, 06:16 PM
  5. Vacuum Table
    By vivagolf in forum DIY CNC Router Table Machines
    Last Post: 11-28-2008, 11:42 PM
