Hi people!!
New guy here, so go easy on me. I have a Fadal 2016. It's a 1999 model with the standard belt driven 7500 rpm spindle. The belt is in excellent shape but it makes a lot of high pitched noise. I know the cogged belts always make a "whining" noise but this is a sort of timed squeak on top of the normal whine. I talked to Fadal about it and the had me spray water on the inside of the belt as a test. The noise went away until the water dried up. So, that supposedly says it's the glazed effect of the belt, and not a spindle problem. Anybody know of a quick fix for this? Maybe a belt dressing that takes away the glazed effect you get over time? I could just replace it, but there's nothing else wrong with it.
