586,364 active members*
3,065 visitors online*
Results 1 to 7 of 7
    Aug 2012
    M03 hangs up CT4500MT
    Greetings once again!
    I'm running a Mazak CyberTurn 4500MT with a Mazatrol 640 control. I've finished turning the OD on my proof part, and am now needing to turn the ID. Due to tool clearance issues I'm using the lower turret for the boring bar. I'm using MasterCam x6 for the CAM side of things and am having the following problem. Here's an excerpt of the code:
    Code:
    N958 O1000   (DRIVE RING SIDE 1 MARK 3  LOWER.NC)
    (POSTED 8-23-12 2:38 PM)
    N960 G0 G18 G20 G40 G80 G97 G99
    N962 G109L2  (LOWER TURRET)
    (***LOWER TOOLS***)
    (T7 - LATHE TOOL 2)
    (T9 - LATHE TOOL 3)
    (T1 - 3/4 SPOT DRILL 8 INCH)
    (T3 -  17/32 DRILL 12 INCH)
    (T5 -  5/8-11 TAPRH)
    (OPERATION 3 )
    (LATHE TOOL 1 )
    (FRONT SIDE ID ROUGHING)
    N964 G54
    N966 G00 T0505
    N968 G18 G99
    N970 G50 S800
    N972 G97 S407 M03
    N974 G96 S500
    N976 G00 Z.335 M08
    N978 G00 X4.6982
    N980 G01 Z.235 F.01
    N982 Z-11.141
    N984 X4.5
    N986 X4.3586 Z-11.0703
    N988 G00 Z.335
    Everything goes fine until I get to N972, which calls a G97 and an M03. I've separated these two commands into separate lines and it goes through the G97 portion just fine, but when it comes to the M03, the machine hangs. No error, no spindle movement, no turret movement, no alarm, nothing. Only a smiling green light above the cycle start button. I've tried removing the M03 just to see, and it progresses happily to the next step. I've tried replacing the M03 with an M04 and the same thing happens. Anybody got any clues?
    Jun 2007
    3757
    G96 is constant surface speed.
    Because no feed rate is selected yet, I suspect it calculates as zero, and just that. Zilch.
    Aug 2012
    The operator was able to get the lower turret moving again, so I inserted an F.01 just above the G97 line this morning and now the machine jumps from N962 to past the end of the program out in white space! If I single block through, it gets through N958 and N960, but upon reaching N962, all text disappears from the EIA monitor window and it just shows the cursor. If I scroll back up, I get to the end of the program. What on earth is going on here?
    Jun 2007
    3757
    Use a hex file editor and look for invisible/invalid characters in the file, or post it here and I will look.
    Aug 2012
    Note: As I've already completed the OD rough and OD finish, I've put a GOTO 958 just below N104. I removed some extra blank lines at the end of the program, but now it just jumps straight to the M30 from N962.
    Code:
    N100 O1000 (DRIVE RING SIDE 1 MARK 3 UPPER.NC)
    N102 G0 G18 G20 G40 G80 G97 G99
    N104 G109L1 (UPPER TURRET)
    (***UPPER TOOLS***)
    (T5 - LATHE TOOL 1)
    (OPERATION 1 )
    (LATHE TOOL 2 )
    (FRONT SIDE OD ROUGHING)
    N106 G54
    N108 G00 T0707
    N110 G18 G99
    N112 M202
    N114 G50 S800
    N116 G97 S150 M04
    N118 G96 S750
    N120 G00 Z.335 M08
    N122 G00 X19.0507
    N124 G01 Z.235 F.01
    N126 Z-10.9148
    N128 X19.25
    N130 X19.45
    N132 G00 Z.335
    N134 X18.8514
    N136 G01 Z.235
    N138 Z-10.9148
    N140 X19.0707
    N142 X19.2707
    N144 G00 Z.335
    N146 X18.6521
    N148 G01 Z.235
    N150 Z-10.9148
    N152 X18.8714
    N154 X19.0714
    N156 G00 Z.335
    N158 X18.4528
    N160 G01 Z.235
    N162 Z-10.4396
    N164 X18.505 Z-10.4658
    N166 G03 X18.52 Z-10.4839 R.0256
    N168 G01 Z-10.9148
    N170 X18.6721
    N172 X18.8721
    N174 G00 Z.335
    N176 X18.2535
    N178 G01 Z.235
    N180 Z-10.427
    N182 X18.4063
    N184 G03 X18.4425 Z-10.4345 R.0256
    N186 G01 X18.4728 Z-10.4496
    N188 X18.6728
    N190 G00 Z.335
    N192 X18.0542
    N194 G01 Z.235
    N196 Z-10.427
    N198 X18.2735
    N200 X18.4735
    N202 G00 Z.335
    N204 X17.8549
    N206 G01 Z.235
    N208 Z-10.427
    N210 X18.0742
    N212 X18.2742
    N214 G00 Z.335
    N216 X17.6555
    N218 G01 Z.235
    N220 Z-10.427
    N222 X17.8749
    N224 X18.0749
    N226 G00 Z.335
    N228 X17.4562
    N230 G01 Z.235
    N232 Z-10.427
    N234 X17.6755
    N236 X17.8755
    N238 G00 Z.335
    N240 X17.2569
    N242 G01 Z.235
    N244 Z-10.427
    N246 X17.4762
    N248 X17.6762
    N250 G00 Z.335
    N252 X17.0576
    N254 G01 Z.235
    N256 Z-10.427
    N258 X17.2769
    N260 X17.4769
    N262 G00 Z.335
    N264 X16.8583
    N266 G01 Z.235
    N268 Z-10.427
    N270 X17.0776
    N272 X17.2776
    N274 G00 Z.335
    N276 X16.659
    N278 G01 Z.235
    N280 Z-10.427
    N282 X16.8783
    N284 X17.0783
    N286 G00 Z.335
    N288 X16.4597
    N290 G01 Z.235
    N292 Z-10.427
    N294 X16.679
    N296 X16.879
    N298 G00 Z.335
    N300 X16.2604
    N302 G01 Z.235
    N304 Z-10.427
    N306 X16.4797
    N308 X16.6797
    N310 G00 Z.335
    N312 X16.0611
    N314 G01 Z.235
    N316 Z-10.427
    N318 X16.2804
    N320 X16.4804
    N322 G00 Z.335
    N324 X15.8618
    N326 G01 Z.235
    N328 Z-9.4286
    N330 G03 X15.895 Z-9.4526 R.0256
    N332 G01 Z-10.4214
    N334 G02 X15.9062 Z-10.427 R.0056
    N336 G01 X16.0811
    N338 X16.2811
    N340 G00 Z.335
    N342 X15.6625
    N344 G01 Z.235
    N346 Z-5.646
    N348 X15.7188
    N350 G03 X15.755 Z-5.6535 R.0256
    N352 G01 X15.8175 Z-5.6848
    N354 G03 X15.8325 Z-5.7029 R.0256
    N356 G01 Z-9.427
    N358 X15.8438
    N360 G03 X15.8818 Z-9.4354 R.0256
    N362 G01 X16.0818 Z-9.4355
    N364 G00 Z.335
    N366 X15.4632
    N368 G01 Z.235
    N370 Z-5.646
    N372 X15.6825
    N374 X15.8825
    N376 G00 Z.335
    N378 X15.2639
    N380 G01 Z.235
    N382 Z-5.646
    N384 X15.4832
    N386 X15.6832
    N388 G00 Z.335
    N390 X15.0646
    N392 G01 Z.235
    N394 Z-5.646
    N396 X15.2839
    N398 X15.4839
    N400 G00 Z.335
    N402 X14.8653
    N404 G01 Z.235
    N406 Z-5.646
    N408 X15.0846
    N410 X15.2846
    N412 G00 Z.335
    N414 X14.6659
    N416 G01 Z.235
    N418 Z-5.646
    N420 X14.8853
    N422 X15.0853
    N424 G00 Z.335
    N426 X14.4666
    N428 G01 Z.235
    N430 Z-5.646
    N432 X14.6859
    N434 X14.8859
    N436 G00 Z.335
    N438 X14.2673
    N440 G01 Z.235
    N442 Z-5.646
    N444 X14.4866
    N446 X14.6866
    N448 G00 Z.335
    N450 X14.068
    N452 G01 Z.235
    N454 Z-5.646
    N456 X14.2873
    N458 X14.4873
    N460 G00 Z.335
    N462 X13.8687
    N464 G01 Z.235
    N466 Z-5.646
    N468 X14.088
    N470 X14.288
    N472 G00 Z.335
    N474 X13.6694
    N476 G01 Z.235
    N478 Z-5.646
    N480 X13.8887
    N482 X14.0887
    N484 G00 Z.335
    N486 X13.4701
    N488 G01 Z.235
    N490 Z-.0426
    N492 X13.505 Z-.06
    N494 G03 X13.52 Z-.0781 R.0256
    N496 G01 Z-4.4844
    N498 G02 X13.5313 Z-4.49 R.0056
    N500 G01 X13.5937
    N502 G03 X13.645 Z-4.5156 R.0256
    N504 G01 Z-5.6404
    N506 G02 X13.6563 Z-5.646 R.0056
    N508 G01 X13.6894
    N510 X13.8894
    N512 G00 Z.335
    N514 X13.2708
    N516 G01 Z.235
    N518 Z.0571
    N520 X13.4901 Z-.0526
    N522 X13.6901
    N524 G00 Z.5536
    N526 X13.0715
    N528 G01 Z.4536
    N530 Z.1567
    N532 X13.2908 Z.0471
    N534 X13.4908
    N536 G00 Z.5536
    N538 X12.8722
    N540 G01 Z.4536
    N542 Z.2564
    N544 X13.0915 Z.1467
    N546 X13.2915
    N548 G00 Z.5268
    N550 X12.5315
    N552 G01 Z.4268
    N554 X12.8922 Z.2464
    N556 X13.0922
    N558 M09
    N560 G28 U0.
    N562 G28 W0.
    N564 M01
    (OPERATION 2 )
    (LATHE TOOL 3 )
    (FRONT SIDE OD FINISHING)
    N566 G54
    N568 G00 T0909
    N570 G18 G99
    N572 G50 S800
    N574 G97 S143 M04
    N576 G96 S500
    N578 G00 Z.155 M08
    N580 G00 X13.3567
    N582 Z.0908
    N584 G01 Z-.0092 F.01
    N586 X13.4817 Z-.0717
    N588 G03 X13.5 Z-.0938 R.0312
    N590 G01 Z-4.5
    N592 X13.5625
    N594 G03 X13.625 Z-4.5313 R.0313
    N596 G01 Z-5.656
    N598 X15.6875
    N600 G03 X15.7317 Z-5.6652 R.0313
    N602 G01 X15.7942 Z-5.6964
    N604 G03 X15.8125 Z-5.7185 R.0312
    N606 G01 Z-9.437
    N608 G03 X15.875 Z-9.4682 R.0313
    N610 G01 Z-10.437
    N612 X18.375
    N614 G03 X18.4192 Z-10.4462 R.0313
    N616 G01 X18.4817 Z-10.4774
    N618 G03 X18.5 Z-10.4995 R.0312
    N620 G01 Z-10.9248
    N622 X18.7
    N624 G00 Z.155
    N626 M09
    N628 G28 U0.
    N630 G28 W0.
    N632 M01
    (OPERATION 4 )
    (LATHE TOOL 2 )
    (FRONT SIDE FACING)
    N634 G54
    N636 G00 T0707
    N638 G18 G99
    N640 G50 S400
    N642 G97 S138 M04
    N644 G96 S500
    N646 G00 Z.155 M08
    N648 G00 X13.8562
    N650 Z.0844
    N652 G01 X11.0057 F.01
    N654 G00 Z.1844
    N656 X13.8562
    N658 Z.01
    N660 G01 X11.0057
    N662 G00 Z.11
    N664 X13.8562
    N666 Z0.
    N668 G01 X11.0057
    N670 G00 Z.1
    N672 M09
    N674 G28 U0.
    N676 G28 W0.
    N678 M05
    N680 M01
    (OPERATION 5 )
    (3/4 SPOT DRILL 8 INCH)
    (FRONT SIDE SPOT DRILL 9-1/2 IN BOLT CIRCLE)
    N682 G54
    N684 G00 T0101
    N686 G17 G98
    N688 M200
    N690 G28 H0.
    N692 M212 (CLAMP OFF)
    N694 G00 C0.
    N696 G00 Z1.5015
    N698 G00 X9.5
    N700 G97 S356 M13
    N702 Z-5.3985
    N704 G83 Z-5.764 R0. F1.42 M210 (CLAMP ON)
    N706 C72.
    N708 C144.
    N710 C216.
    N712 C288.
    N714 G80
    N716 Z1.5015
    (FRONT SIDE SPOT DRILL 12-3/8 IN BOLT CIRCLE)
    N718 M212 (CLAMP OFF)
    N720 X12.375 Z7. C360.
    N722 Z.1
    N724 G83 Z-.328 R0. F1.42 M210 (CLAMP ON)
    N726 C382.5
    N728 C405.
    N730 C427.5
    N732 C450.
    N734 C472.5
    N736 C495.
    N738 C517.5
    N740 C540.
    N742 C562.5
    N744 C585.
    N746 C607.5
    N748 C630.
    N750 C652.5
    N752 C675.
    N754 C697.5
    N756 G80
    N758 Z7.
    (FRONT SIDE SPOT DRILL 14-7/8 IN BOLT CIRCLE)
    N760 M212 (CLAMP OFF)
    N762 X14.875 Z1.344 C720.
    N764 Z-5.556
    N766 G83 Z-5.984 R0. F1.42 M210 (CLAMP ON)
    N768 C750.
    N770 C780.
    N772 C810.
    N774 C840.
    N776 C870.
    N778 C900.
    N780 C930.
    N782 C960.
    N784 C990.
    N786 C1020.
    N788 C1050.
    N790 G80
    N792 Z1.344
    N794 M212 (CLAMP OFF)
    N796 G28 U0.  H0. M15
    N798 G28 W0.
    N800 M01
    (OPERATION 6 )
    ( 17/32 DRILL 12 INCH)
    (FRONT SIDE 27/64 DRILL 9-1/2 IN BOLT CIRCLE)
    N802 G54
    N804 G00 T0443
    N806 G17 G98
    N808 G00 C0.
    N810 G00 Z1.5015 M08
    N812 G00 X9.5
    N814 G97 S356 M13
    N816 Z-5.3985
    N818 G83 Z-7.2485 R0. F1.42 M210 (CLAMP ON)
    N820 C72.
    N822 C144.
    N824 C216.
    N826 C288.
    N828 G80
    N830 Z1.5015
    (OPERATION 7 )
    ( 5/8-11 TAPRH)
    (FRONT SIDE 1/2-13 TAP 9-1/2 IN BOLT CIRCLE)
    N832 G54
    N834 G00 T0711
    N836 G17 G99
    N838 G00 C0.
    N840 G00 Z1.5015 M08
    N842 G00 X9.5
    N844 G97
    N846 Z-5.3985
    N848 M29 S427
    N850 G84 Z-6.9985 R0. F.0909 M210 (CLAMP ON)
    N852 C72.
    N854 C144.
    N856 C216.
    N858 C288.
    N860 G80
    N862 Z1.5015
    (FRONT SIDE 5/8-11 TAP 12-3/8 IN BOLT CIRCLE)
    N864 G97
    N866 M212 (CLAMP OFF)
    N868 X12.375 Z7. C360.
    N870 Z.1
    N872 M29 S356
    N874 G84 Z-2.5 R0. F.0909 M210 (CLAMP ON)
    N876 C382.5
    N878 C405.
    N880 C427.5
    N882 C450.
    N884 C472.5
    N886 C495.
    N888 C517.5
    N890 C540.
    N892 C562.5
    N894 C585.
    N896 C607.5
    N898 C630.
    N900 C652.5
    N902 C675.
    N904 C697.5
    N906 G80
    N908 Z7.
    (FRONT SIDE 5/8-11 TAP 14-7/8 IN BOLT CIRCLE)
    N910 G97
    N912 M212 (CLAMP OFF)
    N914 X14.875 Z1.344 C720.
    N916 Z-5.556
    N918 M29 S356
    N920 G84 Z-7.906 R0. F.0909 M210 (CLAMP ON)
    N922 C750.
    N924 C780.
    N926 C810.
    N928 C840.
    N930 C870.
    N932 C900.
    N934 C930.
    N936 C960.
    N938 C990.
    N940 C1020.
    N942 C1050.
    N944 G80
    N946 Z1.344
    N948 M09
    N950 M212 (CLAMP OFF)
    N952 G28 U0.  H0.
    N954 G28 W0.
    N956 M30
    (***LOWER TOOLS***)
    (T7 - LATHE TOOL 2)
    (T9 - LATHE TOOL 3)
    (T5 -  5/8-11 TAPRH)
    (OPERATION 3 )
    (LATHE TOOL 1 )
    N964 G54
    N966 G00 T0505
    N968 G18 G99
    N970 G50 S800
    M202
    N972 G97 S407 M03
    N974 G96 S500
    N976 G00 Z.335 M08
    N978 G00 X4.6982
    N980 G01 Z.235 F.01
    N982 Z-11.141
    N984 X4.5
    N988 G00 Z.335
    N990 X4.8964
    N992 G01 Z.235
    N994 Z-11.141
    N996 X4.6782
    N998 X4.5368 Z-11.0703
    N1000 G00 Z.335
    N1002 X5.0945
    N1004 G01 Z.235
    N1006 Z-11.141
    N1008 X4.8764
    N1010 X4.7349 Z-11.0703
    N1012 G00 Z.335
    N1014 X5.2927
    N1016 G01 Z.235
    N1018 Z-11.141
    N1020 X5.0745
    N1022 X4.9331 Z-11.0703
    N1024 G00 Z.335
    N1026 X5.4909
    N1028 G01 Z.235
    N1030 Z-11.141
    N1032 X5.2727
    N1034 X5.1313 Z-11.0703
    N1036 G00 Z.335
    N1038 X5.6891
    N1040 G01 Z.235
    N1042 Z-11.141
    N1044 X5.4709
    N1046 X5.3295 Z-11.0703
    N1048 G00 Z.335
    N1050 X5.8873
    N1052 G01 Z.235
    N1054 Z-11.141
    N1056 X5.6691
    N1058 X5.5277 Z-11.0703
    N1060 G00 Z.335
    N1062 X6.0855
    N1064 G01 Z.235
    N1066 Z-11.141
    N1068 X5.8673
    N1070 X5.7259 Z-11.0703
    N1072 G00 Z.335
    N1074 X6.2836
    N1076 G01 Z.235
    N1078 Z-11.141
    N1080 X6.0655
    N1082 X5.924 Z-11.0703
    N1084 G00 Z.335
    N1086 X6.4818
    N1088 G01 Z.235
    N1090 Z-10.9774
    N1092 G02 X6.48 Z-10.9841 R.0256
    N1094 G01 Z-11.141
    N1096 X6.2636
    N1098 X6.1222 Z-11.0703
    N1100 G00 Z.335
    N1102 X6.68
    N1104 G01 Z.235
    N1106 Z-10.9585
    N1108 X6.5313
    N1110 G02 X6.48 Z-10.9841 R.0256
    N1112 G01 Z-11.141
    N1114 X6.4618
    N1116 X6.3204 Z-11.0703
    N1118 G00 Z.335
    N1120 X6.8782
    N1122 G01 Z.235
    N1124 Z-10.9585
    N1126 X6.66
    N1128 X6.5186 Z-10.8878
    N1130 G00 Z.335
    N1132 X7.0764
    N1134 G01 Z.235
    N1136 Z-10.9585
    N1138 X6.8582
    N1140 X6.7168 Z-10.8878
    N1142 G00 Z.335
    N1144 X7.2745
    N1146 G01 Z.235
    N1148 Z-10.9585
    N1150 X7.0564
    N1152 X6.9149 Z-10.8878
    N1154 G00 Z.335
    N1156 X7.4727
    N1158 G01 Z.235
    N1160 Z-10.9576
    N1162 G03 X7.4668 Z-10.9585 R.0056
    N1164 G01 X7.2545
    N1166 X7.1131 Z-10.8878
    N1168 G00 Z.335
    N1170 X7.6709
    N1172 G01 Z.235
    N1174 Z-10.3285
    N1176 X7.5393
    N1178 G02 X7.503 Z-10.336 R.0256
    N1180 G01 X7.493 Z-10.341
    N1182 G02 X7.478 Z-10.3591 R.0256
    N1184 G01 Z-10.9529
    N1186 G03 X7.4668 Z-10.9585 R.0056
    N1188 G01 X7.4527
    N1190 X7.3113 Z-10.8878
    N1192 G00 Z.335
    N1194 X7.8691
    N1196 G01 Z.235
    N1198 Z-5.558
    N1200 X7.868 Z-5.5585
    N1202 G02 X7.853 Z-5.5766 R.0256
    N1204 G01 Z-10.3229
    N1206 G03 X7.8418 Z-10.3285 R.0056
    N1208 G01 X7.6509
    N1210 X7.5095 Z-10.2578
    N1212 G00 Z.335
    N1214 X8.0673
    N1216 G01 Z.235
    N1218 Z-5.4885
    N1220 X8.0292
    N1222 G02 X7.993 Z-5.496 R.0256
    N1224 G01 X7.868 Z-5.5585
    N1226 G02 X7.853 Z-5.5766 R.0256
    N1228 G01 Z-10.3229
    N1230 G03 X7.8491 Z-10.3271 R.0056
    N1232 G01 X7.7077 Z-10.2564
    N1234 G00 Z.335
    N1236 X8.2655
    N1238 G01 Z.235
    N1240 Z-5.4885
    N1242 X8.0473
    N1244 X7.9059 Z-5.4178
    N1246 G00 Z.335
    N1248 X8.4636
    N1250 G01 Z.235
    N1252 Z-5.4885
    N1254 X8.2455
    N1256 X8.104 Z-5.4178
    N1258 G00 Z.335
    N1260 X8.6618
    N1262 G01 Z.235
    N1264 Z-5.4885
    N1266 X8.4436
    N1268 X8.3022 Z-5.4178
    N1270 G00 Z.335
    N1272 X8.86
    N1274 G01 Z.235
    N1276 Z-5.4885
    N1278 X8.6418
    N1280 X8.5004 Z-5.4178
    N1282 G00 Z.335
    N1284 X9.0582
    N1286 G01 Z.235
    N1288 Z-5.4885
    N1290 X8.84
    N1292 X8.6986 Z-5.4178
    N1294 G00 Z.335
    N1296 X9.2564
    N1298 G01 Z.235
    N1300 Z-5.4885
    N1302 X9.0382
    N1304 X8.8968 Z-5.4178
    N1306 G00 Z.335
    N1308 X9.4545
    N1310 G01 Z.235
    N1312 Z-5.4885
    N1314 X9.2364
    N1316 X9.0949 Z-5.4178
    N1318 G00 Z.335
    N1320 X9.6527
    N1322 G01 Z.235
    N1324 Z-5.4885
    N1326 X9.4345
    N1328 X9.2931 Z-5.4178
    N1330 G00 Z.335
    N1332 X9.8509
    N1334 G01 Z.235
    N1336 Z-5.4885
    N1338 X9.6327
    N1340 X9.4913 Z-5.4178
    N1342 G00 Z.335
    N1344 X10.0491
    N1346 G01 Z.235
    N1348 Z-5.4885
    N1350 X9.8309
    N1352 X9.6895 Z-5.4178
    N1354 G00 Z.335
    N1356 X10.2473
    N1358 G01 Z.235
    N1360 Z-5.4885
    N1362 X10.0291
    N1364 X9.8877 Z-5.4178
    N1366 G00 Z.335
    N1368 X10.4455
    N1370 G01 Z.235
    N1372 Z-5.4885
    N1374 X10.2273
    N1376 X10.0859 Z-5.4178
    N1378 G00 Z.335
    N1380 X10.6436
    N1382 G01 Z.235
    N1384 Z-5.4885
    N1386 X10.4255
    N1388 X10.284 Z-5.4178
    N1390 G00 Z.335
    N1392 X10.8418
    N1394 G01 Z.235
    N1396 Z-5.4885
    N1398 X10.6236
    N1400 X10.4822 Z-5.4178
    N1402 G00 Z.335
    N1404 X11.04
    N1406 G01 Z.235
    N1408 Z.125
    N1410 Z-.005
    N1412 X10.995 Z-.0275
    N1414 G02 X10.98 Z-.0456 R.0256
    N1416 G01 Z-5.4829
    N1418 G03 X10.9688 Z-5.4885 R.0056
    N1420 G01 X10.8218
    N1422 X10.6804 Z-5.4178
    (FRONT SIDE ID FINISHING)
    N1424 G96 S200
    N1426 G00 Z.2421
    N1428 X11.3625
    N1430 G01 Z.1421
    N1432 X11.0092 Z-.0346
    N1434 G02 X11. Z-.0456 R.0156
    N1436 G01 Z-5.4829
    N1438 G03 X10.9688 Z-5.4985 R.0156
    N1440 G01 X8.0292
    N1442 G02 X8.0071 Z-5.5031 R.0156
    N1444 G01 X7.8822 Z-5.5656
    N1446 G02 X7.873 Z-5.5766 R.0156
    N1448 G01 Z-10.3229
    N1450 G03 X7.8418 Z-10.3385 R.0156
    N1452 G01 X7.5393
    N1454 G02 X7.5172 Z-10.3431 R.0156
    N1456 G01 X7.5072 Z-10.3481
    N1458 G02 X7.498 Z-10.3591 R.0156
    N1460 G01 Z-10.9529
    N1462 G03 X7.4668 Z-10.9685 R.0156
    N1464 G01 X6.5313
    N1466 G02 X6.5 Z-10.9841 R.0156
    N1468 G01 Z-11.151
    N1470 X6.3586 Z-11.0803
    N1472 G00 Z.155
    N1474 M09
    N1476 G28 U0.
    N1478 G28 W0.
    N1480 M01
    (FRONT SIDE 17/32 DRILL 12-3/8 IN BOLT CIRCLE)
    N1482 M212 (CLAMP OFF)
    N1484 X-12.375 Z7. C360.
    N1486 Z.1
    N1488 G83 Z-2.5 R0. F1.42 M210 (CLAMP ON)
    N1490 C382.5
    N1492 C405.
    N1494 C427.5
    N1496 C450.
    N1498 C472.5
    N1500 C495.
    N1502 C517.5
    N1504 C540.
    N1506 C562.5
    N1508 C585.
    N1510 C607.5
    N1512 C630.
    N1514 C652.5
    N1516 C675.
    N1518 C697.5
    N1520 G80
    N1522 Z7.
    (FRONT SIDE 17/32 DRILL 14-7/8 IN BOLT CIRCLE)
    N1524 M212 (CLAMP OFF)
    N1526 X-14.875 Z1.344 C720.
    N1528 Z-5.556
    N1530 G83 Z-7.906 R0. F1.42 M210 (CLAMP ON)
    N1532 C750.
    N1534 C780.
    N1536 C810.
    N1538 C840.
    N1540 C870.
    N1542 C900.
    N1544 C930.
    N1546 C960.
    N1548 C990.
    N1550 C1020.
    N1552 C1050.
    N1554 G80
    N1556 Z1.344
    N1558 M09
    N1560 M212 (CLAMP OFF)
    N1562 G28 U0.  H0. M15
    N1564 G28 W0.
    N1566 M01
    N1568 M30
    Aug 2012
    Update:
    I went back and cleaned up the code a little bit and reposted through MasterCam and came up with this:
    Code:
    N100 O1000 (70007 UPPER.NC)
    (POSTED 8-24-12 2:40 PM)
    N106 P10 (SYNC)
    (***UPPER TOOLS***)
    (T5 - LATHE TOOL 1)
    (OPERATION 1 )
    (LATHE TOOL 2 )
    N108 G54
    N110 G00 T0707
    N112 G18 G99
    N114 M202
    N116 G50 S800
    N118 G97 S150 M04
    N120 G96 S750
    N122 G00 Z.335 M08
    N124 G00 X19.0507
    N126 G01 Z.235 F.01
    N128 Z-10.9148
    N130 X19.25
    N132 X19.45
    N134 G00 Z.335
    N136 X18.8514
    N138 G01 Z.235
    N140 Z-10.9148
    N142 X19.0707
    N144 X19.2707
    N146 G00 Z.335
    N148 X18.6521
    N150 G01 Z.235
    N152 Z-10.9148
    N154 X18.8714
    N156 X19.0714
    N158 G00 Z.335
    N160 X18.4528
    N162 G01 Z.235
    N164 Z-10.4396
    N166 X18.505 Z-10.4658
    N168 G03 X18.52 Z-10.4839 R.0256
    N170 G01 Z-10.9148
    N172 X18.6721
    N174 X18.8721
    N176 G00 Z.335
    N178 X18.2535
    N180 G01 Z.235
    N182 Z-10.427
    N184 X18.4063
    N186 G03 X18.4425 Z-10.4345 R.0256
    N188 G01 X18.4728 Z-10.4496
    N190 X18.6728
    N192 G00 Z.335
    N194 X18.0542
    N196 G01 Z.235
    N198 Z-10.427
    N200 X18.2735
    N202 X18.4735
    N204 G00 Z.335
    N206 X17.8549
    N208 G01 Z.235
    N210 Z-10.427
    N212 X18.0742
    N214 X18.2742
    N216 G00 Z.335
    N218 X17.6555
    N220 G01 Z.235
    N222 Z-10.427
    N224 X17.8749
    N226 X18.0749
    N228 G00 Z.335
    N230 X17.4562
    N232 G01 Z.235
    N234 Z-10.427
    N236 X17.6755
    N238 X17.8755
    N240 G00 Z.335
    N242 X17.2569
    N244 G01 Z.235
    N246 Z-10.427
    N248 X17.4762
    N250 X17.6762
    N252 G00 Z.335
    N254 X17.0576
    N256 G01 Z.235
    N258 Z-10.427
    N260 X17.2769
    N262 X17.4769
    N264 G00 Z.335
    N266 X16.8583
    N268 G01 Z.235
    N270 Z-10.427
    N272 X17.0776
    N274 X17.2776
    N276 G00 Z.335
    N278 X16.659
    N280 G01 Z.235
    N282 Z-10.427
    N284 X16.8783
    N286 X17.0783
    N288 G00 Z.335
    N290 X16.4597
    N292 G01 Z.235
    N294 Z-10.427
    N296 X16.679
    N298 X16.879
    N300 G00 Z.335
    N302 X16.2604
    N304 G01 Z.235
    N306 Z-10.427
    N308 X16.4797
    N310 X16.6797
    N312 G00 Z.335
    N314 X16.0611
    N316 G01 Z.235
    N318 Z-10.427
    N320 X16.2804
    N322 X16.4804
    N324 G00 Z.335
    N326 X15.8618
    N328 G01 Z.235
    N330 Z-9.4286
    N332 G03 X15.895 Z-9.4526 R.0256
    N334 G01 Z-10.4214
    N336 G02 X15.9062 Z-10.427 R.0056
    N338 G01 X16.0811
    N340 X16.2811
    N342 G00 Z.335
    N344 X15.6625
    N346 G01 Z.235
    N348 Z-5.646
    N350 X15.7188
    N352 G03 X15.755 Z-5.6535 R.0256
    N354 G01 X15.8175 Z-5.6848
    N356 G03 X15.8325 Z-5.7029 R.0256
    N358 G01 Z-9.427
    N360 X15.8438
    N362 G03 X15.8818 Z-9.4354 R.0256
    N364 G01 X16.0818 Z-9.4355
    N366 G00 Z.335
    N368 X15.4632
    N370 G01 Z.235
    N372 Z-5.646
    N374 X15.6825
    N376 X15.8825
    N378 G00 Z.335
    N380 X15.2639
    N382 G01 Z.235
    N384 Z-5.646
    N386 X15.4832
    N388 X15.6832
    N390 G00 Z.335
    N392 X15.0646
    N394 G01 Z.235
    N396 Z-5.646
    N398 X15.2839
    N400 X15.4839
    N402 G00 Z.335
    N404 X14.8653
    N406 G01 Z.235
    N408 Z-5.646
    N410 X15.0846
    N412 X15.2846
    N414 G00 Z.335
    N416 X14.6659
    N418 G01 Z.235
    N420 Z-5.646
    N422 X14.8853
    N424 X15.0853
    N426 G00 Z.335
    N428 X14.4666
    N430 G01 Z.235
    N432 Z-5.646
    N434 X14.6859
    N436 X14.8859
    N438 G00 Z.335
    N440 X14.2673
    N442 G01 Z.235
    N444 Z-5.646
    N446 X14.4866
    N448 X14.6866
    N450 G00 Z.335
    N452 X14.068
    N454 G01 Z.235
    N456 Z-5.646
    N458 X14.2873
    N460 X14.4873
    N462 G00 Z.335
    N464 X13.8687
    N466 G01 Z.235
    N468 Z-5.646
    N470 X14.088
    N472 X14.288
    N474 G00 Z.335
    N476 X13.6694
    N478 G01 Z.235
    N480 Z-5.646
    N482 X13.8887
    N484 X14.0887
    N486 G00 Z.335
    N488 X13.4701
    N490 G01 Z.235
    N492 Z-.0426
    N494 X13.505 Z-.06
    N496 G03 X13.52 Z-.0781 R.0256
    N498 G01 Z-4.4844
    N500 G02 X13.5313 Z-4.49 R.0056
    N502 G01 X13.5937
    N504 G03 X13.645 Z-4.5156 R.0256
    N506 G01 Z-5.6404
    N508 G02 X13.6563 Z-5.646 R.0056
    N510 G01 X13.6894
    N512 X13.8894
    N514 G00 Z.335
    N516 X13.2708
    N518 G01 Z.235
    N520 Z.0571
    N522 X13.4901 Z-.0526
    N524 X13.6901
    N526 G00 Z.5536
    N528 X13.0715
    N530 G01 Z.4536
    N532 Z.1567
    N534 X13.2908 Z.0471
    N536 X13.4908
    N538 G00 Z.5536
    N540 X12.8722
    N542 G01 Z.4536
    N544 Z.2564
    N546 X13.0915 Z.1467
    N548 X13.2915
    N550 G00 Z.5268
    N552 X12.5315
    N554 G01 Z.4268
    N556 X12.8922 Z.2464
    N558 X13.0922
    N560 M09
    N562 G28 U0.
    N564 G28 W0.
    N566 M01
    (OPERATION 2 )
    (LATHE TOOL 3 )
    N568 G54
    N570 G00 T0909
    N572 G18 G99
    N574 G50 S800
    N576 G97 S143 M04
    N578 G96 S500
    N580 G00 Z.155 M08
    N582 G00 X13.3567
    N584 Z.0908
    N586 G01 Z-.0092 F.01
    N588 X13.4817 Z-.0717
    N590 G03 X13.5 Z-.0938 R.0312
    N592 G01 Z-4.5
    N594 X13.5625
    N596 G03 X13.625 Z-4.5313 R.0313
    N598 G01 Z-5.656
    N600 X15.6875
    N602 G03 X15.7317 Z-5.6652 R.0313
    N604 G01 X15.7942 Z-5.6964
    N606 G03 X15.8125 Z-5.7185 R.0312
    N608 G01 Z-9.437
    N610 G03 X15.875 Z-9.4682 R.0313
    N612 G01 Z-10.437
    N614 X18.375
    N616 G03 X18.4192 Z-10.4462 R.0313
    N618 G01 X18.4817 Z-10.4774
    N620 G03 X18.5 Z-10.4995 R.0312
    N622 G01 Z-10.9248
    N624 X18.7
    N626 G00 Z.155
    N628 M09
    N630 G28 U0.
    N632 G28 W0.
    N634 M01
    N636 P11 (SYNC)
    N638 P12 (WAIT)
    (OPERATION 4 )
    (LATHE TOOL 2 )
    (FRONT SIDE FACING)
    N640 G54
    N642 G00 T0707
    N644 G18 G99
    N646 G50 S400
    N648 G97 S138 M04
    N650 G96 S500
    N652 G00 Z.155 M08
    N654 G00 X13.8562
    N656 Z.0844
    N658 G01 X11.0057 F.01
    N660 G00 Z.1844
    N662 X13.8562
    N664 Z.01
    N666 G01 X11.0057
    N668 G00 Z.11
    N670 X13.8562
    N672 Z0.
    N674 G01 X11.0057
    N676 G00 Z.1
    N678 M09
    N680 G28 U0.
    N682 G28 W0.
    N684 M05
    N686 M01
    (OPERATION 5 )
    N688 G54
    N690 G00 T0101
    N692 G17 G98
    N694 M200
    N696 G28 H0.
    N698 M212 (CLAMP OFF)
    N700 G00 C0.
    N702 G00 Z1.5015
    N704 G00 X9.5
    N706 G97 S356 M13
    N708 Z-5.3985
    N710 G83 Z-5.764 R0. F1.42 M210 (CLAMP ON)
    N712 C72.
    N714 C144.
    N716 C216.
    N718 C288.
    N720 G80
    N722 Z1.5015
    N724 M212 (CLAMP OFF)
    N726 X12.375 Z7. C360.
    N728 Z.1
    N730 G83 Z-.328 R0. F1.42 M210 (CLAMP ON)
    N732 C382.5
    N734 C405.
    N736 C427.5
    N738 C450.
    N740 C472.5
    N742 C495.
    N744 C517.5
    N746 C540.
    N748 C562.5
    N750 C585.
    N752 C607.5
    N754 C630.
    N756 C652.5
    N758 C675.
    N760 C697.5
    N762 G80
    N764 Z7.
    N766 M212 (CLAMP OFF)
    N768 X14.875 Z1.344 C720.
    N770 Z-5.556
    N772 G83 Z-5.984 R0. F1.42 M210 (CLAMP ON)
    N774 C750.
    N776 C780.
    N778 C810.
    N780 C840.
    N782 C870.
    N784 C900.
    N786 C930.
    N788 C960.
    N790 C990.
    N792 C1020.
    N794 C1050.
    N796 G80
    N798 Z1.344
    N800 M212 (CLAMP OFF)
    N802 G28 U0.  H0. M15
    N804 G28 W0.
    N806 M01
    (OPERATION 6 )
    N808 G54
    N810 G00 T0443
    N812 G17 G98
    N814 G00 C0.
    N816 G00 Z1.5015 M08
    N818 G00 X9.5
    N820 G97 S356 M13
    N822 Z-5.3985
    N824 G83 Z-7.2485 R0. F1.42 M210 (CLAMP ON)
    N826 C72.
    N828 C144.
    N830 C216.
    N832 C288.
    N834 G80
    N836 Z1.5015
    N838 M212 (CLAMP OFF)
    N840 X12.375 Z7. C360.
    N842 Z.1
    N844 G83 Z-2.5 R0. F1.42 M210 (CLAMP ON)
    N846 C382.5
    N848 C405.
    N850 C427.5
    N852 C450.
    N854 C472.5
    N856 C495.
    N858 C517.5
    N860 C540.
    N862 C562.5
    N864 C585.
    N866 C607.5
    N868 C630.
    N870 C652.5
    N872 C675.
    N874 C697.5
    N876 G80
    N878 Z7.
    N880 M212 (CLAMP OFF)
    N882 X14.875 Z1.344 C720.
    N884 Z-5.556
    N886 G83 Z-7.906 R0. F1.42 M210 (CLAMP ON)
    N888 C750.
    N890 C780.
    N892 C810.
    N894 C840.
    N896 C870.
    N898 C900.
    N900 C930.
    N902 C960.
    N904 C990.
    N906 C1020.
    N908 C1050.
    N910 G80
    N912 Z1.344
    N914 M09
    N916 M212 (CLAMP OFF)
    N918 G28 U0.  H0. M15
    N920 G28 W0.
    N922 M01
    (OPERATION 7 )
    ( 5/8-11 TAPRH)
    (FRONT SIDE 5/8-11 TAP 9-1/2 IN BOLT CIRCLE)
    N924 G54
    N926 G00 T0711
    N928 G17 G99
    N930 G00 C0.
    N932 G00 Z1.5015 M08
    N934 G00 X9.5
    N936 G97
    N938 Z-5.3985
    N940 M29 S427
    N942 G84 Z-6.9985 R0. F.0909 M210 (CLAMP ON)
    N944 C72.
    N946 C144.
    N948 C216.
    N950 C288.
    N952 G80
    N954 Z1.5015
    N956 G97
    N958 M212 (CLAMP OFF)
    N960 X12.375 Z7. C360.
    N962 Z.1
    N964 M29 S356
    N966 G84 Z-2.5 R0. F.0909 M210 (CLAMP ON)
    N968 C382.5
    N970 C405.
    N972 C427.5
    N974 C450.
    N976 C472.5
    N978 C495.
    N980 C517.5
    N982 C540.
    N984 C562.5
    N986 C585.
    N988 C607.5
    N990 C630.
    N992 C652.5
    N994 C675.
    N996 C697.5
    N998 G80
    N1000 Z7.
    N1002 G97
    N1004 M212 (CLAMP OFF)
    N1006 X14.875 Z1.344 C720.
    N1008 Z-5.556
    N1010 M29 S356
    N1012 G84 Z-7.906 R0. F.0909 M210 (CLAMP ON)
    N1014 C750.
    N1016 C780.
    N1018 C810.
    N1020 C840.
    N1022 C870.
    N1024 C900.
    N1026 C930.
    N1028 C960.
    N1030 C990.
    N1032 C1020.
    N1034 C1050.
    N1036 G80
    N1038 Z1.344
    N1040 M09
    N1042 M212 (CLAMP OFF)
    N1044 G28 U0.  H0.
    N1046 G28 W0.
    N1048 P13 (SYNC)
    N1050 M30
    N1052 O1000   (70007  LOWER.NC)
    N1054 G0 G18 G20 G40 G80 G97 G99
    N1056 G109L2  (LOWER TURRET)
    N1058 P10 (SYNC)
    N1060 P11 (WAIT)
    (***LOWER TOOLS***)
    (T5 -  DNMG Boring Bar)
    (OPERATION 3 )
    (LATHE TOOL 1 )
    N1062 G54
    N1064 G00 T0505
    N1066 G18 G99
    N1068 G50 S400
    N1070 G97 S400 M03
    N1072 G96 S500
    N1074 G00 Z.335 M08
    N1076 G00 X4.6982
    N1078 G01 Z.235 F.01
    N1080 Z-11.141
    N1082 X4.5
    N1084 X4.3586 Z-11.0703
    N1086 G00 Z.335
    N1088 X4.8964
    N1090 G01 Z.235
    N1092 Z-11.141
    N1094 X4.6782
    N1096 X4.5368 Z-11.0703
    N1098 G00 Z.335
    N1100 X5.0945
    N1102 G01 Z.235
    N1104 Z-11.141
    N1106 X4.8764
    N1108 X4.7349 Z-11.0703
    N1110 G00 Z.335
    N1112 X5.2927
    N1114 G01 Z.235
    N1116 Z-11.141
    N1118 X5.0745
    N1120 X4.9331 Z-11.0703
    N1122 G00 Z.335
    N1124 X5.4909
    N1126 G01 Z.235
    N1128 Z-11.141
    N1130 X5.2727
    N1132 X5.1313 Z-11.0703
    N1134 G00 Z.335
    N1136 X5.6891
    N1138 G01 Z.235
    N1140 Z-11.141
    N1142 X5.4709
    N1144 X5.3295 Z-11.0703
    N1146 G00 Z.335
    N1148 X5.8873
    N1150 G01 Z.235
    N1152 Z-11.141
    N1154 X5.6691
    N1156 X5.5277 Z-11.0703
    N1158 G00 Z.335
    N1160 X6.0855
    N1162 G01 Z.235
    N1164 Z-11.141
    N1166 X5.8673
    N1168 X5.7259 Z-11.0703
    N1170 G00 Z.335
    N1172 X6.2836
    N1174 G01 Z.235
    N1176 Z-11.141
    N1178 X6.0655
    N1180 X5.924 Z-11.0703
    N1182 G00 Z.335
    N1184 X6.4818
    N1186 G01 Z.235
    N1188 Z-10.9774
    N1190 G02 X6.48 Z-10.9841 R.0256
    N1192 G01 Z-11.141
    N1194 X6.2636
    N1196 X6.1222 Z-11.0703
    N1198 G00 Z.335
    N1200 X6.68
    N1202 G01 Z.235
    N1204 Z-10.9585
    N1206 X6.5313
    N1208 G02 X6.48 Z-10.9841 R.0256
    N1210 G01 Z-11.141
    N1212 X6.4618
    N1214 X6.3204 Z-11.0703
    N1216 G00 Z.335
    N1218 X6.8782
    N1220 G01 Z.235
    N1222 Z-10.9585
    N1224 X6.66
    N1226 X6.5186 Z-10.8878
    N1228 G00 Z.335
    N1230 X7.0764
    N1232 G01 Z.235
    N1234 Z-10.9585
    N1236 X6.8582
    N1238 X6.7168 Z-10.8878
    N1240 G00 Z.335
    N1242 X7.2745
    N1244 G01 Z.235
    N1246 Z-10.9585
    N1248 X7.0564
    N1250 X6.9149 Z-10.8878
    N1252 G00 Z.335
    N1254 X7.4727
    N1256 G01 Z.235
    N1258 Z-10.9576
    N1260 G03 X7.4668 Z-10.9585 R.0056
    N1262 G01 X7.2545
    N1264 X7.1131 Z-10.8878
    N1266 G00 Z.335
    N1268 X7.6709
    N1270 G01 Z.235
    N1272 Z-10.3285
    N1274 X7.5393
    N1276 G02 X7.503 Z-10.336 R.0256
    N1278 G01 X7.493 Z-10.341
    N1280 G02 X7.478 Z-10.3591 R.0256
    N1282 G01 Z-10.9529
    N1284 G03 X7.4668 Z-10.9585 R.0056
    N1286 G01 X7.4527
    N1288 X7.3113 Z-10.8878
    N1290 G00 Z.335
    N1292 X7.8691
    N1294 G01 Z.235
    N1296 Z-5.558
    N1298 X7.868 Z-5.5585
    N1300 G02 X7.853 Z-5.5766 R.0256
    N1302 G01 Z-10.3229
    N1304 G03 X7.8418 Z-10.3285 R.0056
    N1306 G01 X7.6509
    N1308 X7.5095 Z-10.2578
    N1310 G00 Z.335
    N1312 X8.0673
    N1314 G01 Z.235
    N1316 Z-5.4885
    N1318 X8.0292
    N1320 G02 X7.993 Z-5.496 R.0256
    N1322 G01 X7.868 Z-5.5585
    N1324 G02 X7.853 Z-5.5766 R.0256
    N1326 G01 Z-10.3229
    N1328 G03 X7.8491 Z-10.3271 R.0056
    N1330 G01 X7.7077 Z-10.2564
    N1332 G00 Z.335
    N1334 X8.2655
    N1336 G01 Z.235
    N1338 Z-5.4885
    N1340 X8.0473
    N1342 X7.9059 Z-5.4178
    N1344 G00 Z.335
    N1346 X8.4636
    N1348 G01 Z.235
    N1350 Z-5.4885
    N1352 X8.2455
    N1354 X8.104 Z-5.4178
    N1356 G00 Z.335
    N1358 X8.6618
    N1360 G01 Z.235
    N1362 Z-5.4885
    N1364 X8.4436
    N1366 X8.3022 Z-5.4178
    N1368 G00 Z.335
    N1370 X8.86
    N1372 G01 Z.235
    N1374 Z-5.4885
    N1376 X8.6418
    N1378 X8.5004 Z-5.4178
    N1380 G00 Z.335
    N1382 X9.0582
    N1384 G01 Z.235
    N1386 Z-5.4885
    N1388 X8.84
    N1390 X8.6986 Z-5.4178
    N1392 G00 Z.335
    N1394 X9.2564
    N1396 G01 Z.235
    N1398 Z-5.4885
    N1400 X9.0382
    N1402 X8.8968 Z-5.4178
    N1404 G00 Z.335
    N1406 X9.4545
    N1408 G01 Z.235
    N1410 Z-5.4885
    N1412 X9.2364
    N1414 X9.0949 Z-5.4178
    N1416 G00 Z.335
    N1418 X9.6527
    N1420 G01 Z.235
    N1422 Z-5.4885
    N1424 X9.4345
    N1426 X9.2931 Z-5.4178
    N1428 G00 Z.335
    N1430 X9.8509
    N1432 G01 Z.235
    N1434 Z-5.4885
    N1436 X9.6327
    N1438 X9.4913 Z-5.4178
    N1440 G00 Z.335
    N1442 X10.0491
    N1444 G01 Z.235
    N1446 Z-5.4885
    N1448 X9.8309
    N1450 X9.6895 Z-5.4178
    N1452 G00 Z.335
    N1454 X10.2473
    N1456 G01 Z.235
    N1458 Z-5.4885
    N1460 X10.0291
    N1462 X9.8877 Z-5.4178
    N1464 G00 Z.335
    N1466 X10.4455
    N1468 G01 Z.235
    N1470 Z-5.4885
    N1472 X10.2273
    N1474 X10.0859 Z-5.4178
    N1476 G00 Z.335
    N1478 X10.6436
    N1480 G01 Z.235
    N1482 Z-5.4885
    N1484 X10.4255
    N1486 X10.284 Z-5.4178
    N1488 G00 Z.335
    N1490 X10.8418
    N1492 G01 Z.235
    N1494 Z-5.4885
    N1496 X10.6236
    N1498 X10.4822 Z-5.4178
    N1500 G00 Z.335
    N1502 X11.04
    N1504 G01 Z.235
    N1506 Z.125
    N1508 Z-.005
    N1510 X10.995 Z-.0275
    N1512 G02 X10.98 Z-.0456 R.0256
    N1514 G01 Z-5.4829
    N1516 G03 X10.9688 Z-5.4885 R.0056
    N1518 G01 X10.8218
    N1520 X10.6804 Z-5.4178
    N1522 G96 S200
    N1524 G00 Z.2421
    N1526 X11.3625
    N1528 G01 Z.1421
    N1530 X11.0092 Z-.0346
    N1532 G02 X11. Z-.0456 R.0156
    N1534 G01 Z-5.4829
    N1536 G03 X10.9688 Z-5.4985 R.0156
    N1538 G01 X8.0292
    N1540 G02 X8.0071 Z-5.5031 R.0156
    N1542 G01 X7.8822 Z-5.5656
    N1544 G02 X7.873 Z-5.5766 R.0156
    N1546 G01 Z-10.3229
    N1548 G03 X7.8418 Z-10.3385 R.0156
    N1550 G01 X7.5393
    N1552 G02 X7.5172 Z-10.3431 R.0156
    N1554 G01 X7.5072 Z-10.3481
    N1556 G02 X7.498 Z-10.3591 R.0156
    N1558 G01 Z-10.9529
    N1560 G03 X7.4668 Z-10.9685 R.0156
    N1562 G01 X6.5313
    N1564 G02 X6.5 Z-10.9841 R.0156
    N1566 G01 Z-11.151
    N1568 X6.3586 Z-11.0803
    N1570 G00 Z.155
    N1572 M09
    N1574 G28 U0.
    N1576 G28 W0.
    N1578 M01
    N1580 P12 (SYNC)
    N1582 P13 (WAIT)
    N1584 M30
    After removing all the % signs (my machine doesn't seem to like these), and adding a "GOTO 634" above N108 to skip the OD Roughing and OD Finishing portions of the program, it runs through to line 1070 and hangs up on M03. I tried moving the M03 to its own line below the G96 line, as this should specify a spindle rate (right?), and it goes on through to the M03 and hangs up. Why would an M03 hang up this machine? As you can see, if I've already moved the M03 below the G96 in line 1074, it should have the spindle speed it needs, right?
    Jun 2007
    3757
    At line 1068 you've set your max speed to 400, so any attempt to demand above 400 will fail.
    Just edit the file and change 1068 to G50 S550 and see what happens.
    You need to find the current cause, and just reposting will move the problem.
    If machine doesn't like the % then you are not using the proper post for the machine control, or the post is corrupted (read that as 'did someone change it')
  1. Tool changer hangs up.
    By jimmy111 in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2012, 10:21 PM
  2. madCAM hangs.
    By Odd Egeland in forum MadCAM
    Last Post: 03-19-2010, 01:00 PM
  3. Program Hangs!
    By WOODKNACK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-18-2003, 05:19 PM
