587,070 active members*
3,032 visitors online*
Results 1 to 7 of 7
    Oct 2005
    7
    Miyano TSV23 +Hass 5c
    Does anyone have the wiring diagrams to connect a Hass 5C indexing table to a Miyano TSV 23?
    Jul 2009
    80
    Hi
    Do you have the controller box for the 5C?
    Robby
    Oct 2005
    7
    I have the Hass 5C and manual, I,m looking for the terminal numbers on the TSV23
    Jul 2009
    80
    Hello Handasee
    I will attach a picture of board you might have on your machine.
    There are two ways you can work with this unit 5C on your Miyano.
    As I mention with your controller box is possible to program certain degrees and interact with milling or drilling program, as Indexer.
    If you add M00 at your program and place Box controller on top of machine panel, cycle start directly to controller. it will index to programmed position and then you can continue with cycle start on the machine....
    Second option which is the best, I am thinking you have electrical diagrams and perhaps know which M code (spare) have on your machine.
    there is need of only one and M FIN signal, normally on I/O board.
    On your program command MXX and control sends moving command thru cable wired to this optional M Relay (Picture attached) and then M FIN signal is returned to machine and cycle continues.
    At this moment I am trying to find these two options for your machine
    I/O I´m looking is A16B-1211-0941, same as yours?
    Best of luck
    Robby
    Jul 2009
    80
    Handasse
    I have found what you need for interface with HAAS 5C
    Attached check drawings.
    you can use M20, M21, or M22. for program.
    you have to have TB1 which is optional M code relay
    signal is handled thru TA, TI board (MFIN).
    any question I will be in touch.
    if you have parameter list for this machine, I´ll appreciate your help.
    Best of luck
    Robby
    Attached Files Attached Files
    Jul 2009
    80
    Hello Out there!
    If someone has Miyano TSV 23 Parameters
    It will be greatly appreciated.
    I only have 900 parameters.
    Regards
    Robby
    Aug 2007
    44
    Miyano TSV32
    I need help macro program for Miyano TSV 23
    O9003
  1. hass 160 alarm
    By s00073055 in forum Haas Mills
    Last Post: 01-10-2016, 03:45 AM
  2. hass d offsets
    By antny in forum OneCNC
    Last Post: 07-20-2009, 03:50 AM
  3. OneCNC & Hass
    By l u k e in forum Haas Mills
    Last Post: 09-02-2008, 01:08 AM
  4. looking to buy USED HASS CNC mill
    By H_U_S_S_A_M in forum Want To Buy...Need help!
    Last Post: 04-23-2008, 10:46 PM
  5. Wireless RS-232 to Hass VF-2
    By Gujustud in forum DNC Problems and Solutions
    Last Post: 04-12-2006, 10:44 AM
