586,540 active members*
2,958 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > Fanuc or Siemens or Mitsubishi
Results 1 to 14 of 14
    Aug 2005
    6
    Which One and Why?
    Chippy
    Dec 2003
    24223
    From the Retro-fit side, of the three, I would pick Mitsubishi every time, Fanuc are expensive and as a company, hard to get along with, although a good control.
    Siemens NT based but I have witnessed a fairly high rate of failures in the ones I have experience with.
    Mitsubishi, easy to work with, both product and company, easy to get support, reliable control.
    Al.
    Albert E.
    Oct 2005
    8
    Siemens I would say.
    I read five minutes ago first time about mitsubishi having some kind of control (at least here in europe not very popular)
    I have ten years experience of fanuc and siemens, and the first 0T controls did not have even common variables, as siemens 3T was way ahead with everything(with R parameters).
    And today I can control up to (correct if I´m wrong) 11 axes simultaneous with sinumerik840.
    And fanuc has Series 18i-MODEL B which can control up to 8 axes control, and only 4 of those axes simultaneous.
    Aug 2005
    6
    Johnmirra,
    Did you know that Mazak is 99% Mitsubishi, Mori is 45% Mitsubishi, and Citizen is 95% Mitsubishi? Mitsubishi is hidden behind the name Mazatrol, Mapps, and Cincom.
    Regards,
    Chippy
    Chippy
    Oct 2005
    8
    Dumonts,
    Those are more familiar names.
    Is there some machine having 100% Mitsu?
    Apr 2005
    629
    WHy not look at Yasakawa?
    Aug 2005
    6
    Johnmirra,
    For the most part OEM's I think remain flexible and do not use any one control because they may loose business to multiple customers who may have preference to the machine, but like to keep the control the same in their shop. There operators are more familiar with one control then multiple. I'm sure there are many pros and cons to argue this point.
    Chris D,
    Good point what about Yaskawa. I wasn't so sure how big Yaskawa is any more. Can you enlighten me?
    Regards,
    Chippy
    Chippy
    Dec 2004
    167
    Haas and Milltronics are using Yaskawa drives and servoes.
    Sep 2003
    552
    Yasnac=Yaskawa
    Darek
    Apr 2005
    629
    Quote Originally Posted by dumonts
    Johnmirra,
    Chris D,
    Regards,
    Chippy
    Yaskawa is located in Waukegan IL and they have a very nice, big facility. I drive by it pretty often as I have an industrial client right next door. I no longer know any of the engineers there but used to know several - all good people. You may want to look into them pretty closely.
    Also, to add another builder to the Yasnac (yaskawa) users is Mori, I know they used their controls a few years back but have since lost track of who is using what these days.
    Chris
    Apr 2005
    3634
    Siemens 840D. It's what I know/use. Most of the time it runs good. Last night at work was the exception, Kept freezing up, had to restart 5 times! (nuts)
    Aug 2005
    6
    Switcher,
    Hows Siemens service to get ahold of? Easy to work with?
    Chippy
    Apr 2005
    3634
    dumonts,
    The company I work for doesn't deal directly with "Siemens", The machine is from "Schutte", so that is who they work with.
    I think the machine is just rebranded with the "Schutte" name. The outside of the machine has everything labled "Schutte", everything on the inside is labled "Siemens".
    "Schutte" usually has next day service.
    So, I guess I'm not much help with your ?s, sorry.
    Jun 2005
    99% of the Machines in the Shop I work in use Fanuc, I've used Siemens a couple times, it isn't bad but I prefer Fanuc. We have one Mitsubishi but, I've never run it.
