586,500 active members*
1,860 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > 110 sdu alarm question
    Dec 2009
    67
    Hey guys yesterday as i was running my lathe (LB 15 5020L controller) and noticed that my rpms started varying. Basically it was speeding up and slowing down.I was boring my soft jaws so everything was in manual, I stopped the spindle when i noticed it and when i went to restart and got a 110 SDU alarm. I shut the machine down completly and restarted and everything worked fine for about three hours and then it alarmed out one other time in auto. Once again I shut it down and restarted then finished out the day with no troubles. Do any you guys have an idea of what might be going on?Im very much a novice on cnc stuff and any help would be greatly appreciated...
    Feb 2008
    52
    110 alarm.pdf
    sounds like somthing on the drive is getting hot and opening up and letting the siginals drop. What kind of VAC drive and is there a number or lights on or flashing when the machine alarms out?
    any mechanical or electrical device that transmits or modifies energy to perform or assist in the performance of human tasks
    Dec 2009
    67
    Ok, since i made this post I learned that there were alarm codes on sdu. It has only alarmed out those two times, since then no problems. When i had my alarms i didnt know about alarm code lights, so not much help there. I will come back and post if i have anymore alarms. After I read your post i did clean the fan that cools heat sink, it was pretty nasty! Everything else is good. As far as what kind of VAC drive, im not sure what you need. Is it a # or name brand and where might I find the info your aking for. Thanks for your help!!!!
    Mar 2011
    23
    hi, did you fix your machine i have same problem any advice how to fix?
    thanks
  1. Alarm (low lube,pressure) question
    By BMackinnon in forum Haas Mills
    Last Post: 05-31-2020, 12:53 PM
  2. Fanuc 0M servo alarm question
    By geeserteg in forum Fanuc
    Last Post: 03-29-2016, 04:32 PM
  3. A axis alarm question
    By panaceabea in forum Haas Mills
    Last Post: 04-05-2009, 06:31 PM
  4. Tool length alarm question????
    By theemudracer in forum Fanuc
    Last Post: 05-19-2007, 09:56 PM
  5. Question about alarm EZ-trak II
    By frankc in forum Bridgeport / Hardinge Mills
    Last Post: 10-18-2005, 06:36 PM
