586,110 active members*
3,293 visitors online*
Results 1 to 3 of 3
    Apr 2010
    260
    Milling 15-5Ph
    I have a customer that wants us to make a part out of 15-5ph. It will require milling of slots, profile cutting, drilling, reaming and broaching. What is your expierience cutting this material. We cut alot of 304SS, is it comparable to that. Cut wet with variable helix carbide tooling...
    www.machmachine.com
    Jul 2010
    15-5
    According to the specs at aksteel.com, its just a ferrite free version of 17-4. Use carbide tooling with sharp edges(minimum edge prep) and a quality coolant such as syntillo 9913. Myself, I would use TIN coated endmills rather than TIALN. High speed machining is ideal for this type of material. I have a video on youtube that shows what can be done with 17-4 ss. Good luck.
    [nomedia="http://www.youtube.com/watch?v=E3AqIZURMbI"]YouTube - HIGH SPEED MACHINING(REALLY HIGH!!!)[/nomedia]
    Apr 2010
    260
    thanks. When we cut other SS like 17-4 or 304 we use SGS z carb endmills. The are nothing short of amazing. When we first started cutting with them I was like no way you can run it at that speed/feed DOC at 100% engagement
    www.machmachine.com
  1. Retrofit my Old Milling (Milling No. 0)
    By mistry_hemant in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-17-2011, 11:08 AM
  2. RFQ - CNC Milling. *UK ONLY*
    By Babba in forum Employment Opportunity
    Last Post: 01-12-2011, 11:45 PM
  3. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
  4. Offset Chain Milling vs Path Milling
    By ynnek in forum Uncategorised CAM Discussion
    Last Post: 03-11-2009, 11:29 PM
  5. Milling with bottom vs milling with side?
    By REVCAM_Bob in forum Community Club House
    Last Post: 06-30-2008, 03:23 PM
