i am relative new in MadCam, and just did some simple stuff.
Now i got the problem with a 3D Modell, which i would mill like this:
1- 6mm Cutter - 3D Roughing
2- 2mm Cutter - 3D Z-Level Finishing
3- 2mm Cutter - 3D Planar Finishing
my problem is, that there is so much material left, after the first two steps,
that my cutter will break - or did...
So like you can see on the attached picture, i tried it with short cutting lenght of the tool, and thought that madcam will split the height to this value.
As example - Step3 - 3D Planar Finishing - I took the 2mm cutter with a cutting lenght of 0.2mm so madcam should do 0.2mm steps in Z-Level?
Am i doing something wrong, do i have to choose some other strategie?
Thanks for your help.
Robert
You didn't mention the material, but regardless, I would discourage finishing with such a tiny cutter. Even stepping up to a Ø3mm cutter will make a huge difference, but in my opinion, I would suggest using a larger cutter to finish, and save the tiny cutters for re-machining.
As for setting the step-down for z-level finishing, adjusting the cutter length will have no effect. You need to set that on the page that appears when you select the Z-level finishing path. Please take a look at the screen shot.
Hope this helps,
Dan
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
