586,117 active members*
3,470 visitors online*
Results 1 to 8 of 8
    Identify this insert
    I'm a complete newbie when it comes to Indexable endmills, so bear with me. Can anyone identify this insert? It's a 1/2" diameter, and I've been told it *could* be a WPB-N.
    Proud owner of a Series II Bridgeport.
    Apr 2003
    1873
    Hey Andrew,
    Sorry, cant help with the insert, but havn't seen any post recently on your Bridgeport Series II conversion, hows it going ?
    I just posted an update.
    927
    Andrew,
    It looks like a "Flat Nose Dapra Finish" insert...
    Here: http://www.dapra.com/cutting/ballnose/inserts.htm
    Thanks WMS!
    A more important question might be, am I going to be able to do slotting in Aluminum with something like this?
    Aug 2004
    2849
    I don't see why not...try it
    Jun 2003
    513
    That is a backdraft tool. It is used primarily as a finishing tool for 3 axis machining and for pocketing using light depths of cut. It is not designed for slotting and I wouldn't recommend using it for that.
    May 2005
    90
    lmt fette has tools like that
    i have bought 2 of their finishing balls mills in that form
