Software and GCode Recommendations with Oxy-Fuel CNC
Until I get the funds for a plasma system I'd like to hook up my oxy-fuel (oxy acetylene currently) torch to my CNC Gantry. The hardware is not so much of a concern as how to alter/configure GCode for use with oxy-fuel as well as any configuration changes that should be made to Mach3.
Currently the machine is set up for cutting wood and plastic with a router. What I really need to know is the tips and tricks in writing any GCode to allow sufficient time for the heating process to take place before cutting with oxy, and any changes to Mach3 that might work well.
I would appreciate any suggestions for electronics devices or additional software that would be useful. Cutting with a plasma torch seems more simple and straight-forward in terms of operation due to it's electronic nature with the ability to stop and start the plasma cutter electronically, monitor voltages, etc. For now I just want to cut some metal with the oxy-fuel torch. Thanks!!!
He is more machine now than man.....
