586,395 active members*
2,811 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Parameter Bank Select Viper 95
    May 2006
    18
    Hi Larry,
    Manual V2.0.1 shows the Parameter Bank Select jumpers (Page 32).
    What I cannot find is which end of the plug I should count from.
    ie Is the reverse motor jumper nearest the board edge or opposite edge.
    I dont see any printed info on the PCB itself.
    I dont want to stick jumpers on to find out I have counted from the wrong end.
    John
    Feb 2007
    966
    The bottom of the board is there the motor connectors are. (The encoder and motor output)
    The top is the 5pin programming connector. The reverse jumper is at the top.
    Larry
    May 2006
    18
    I will mark my manual appropriately.
    Regards
    John
  1. PIC18F bank access
    By The Blight in forum PIC Programing / Design
    Last Post: 04-21-2024, 01:39 PM
  2. Viper V-950/OS crashed,lost all parameter
    By jesse297 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-18-2022, 07:45 PM
  3. Capacitor Bank Help
    By Shanghyd in forum Phase Converters
    Last Post: 08-18-2009, 05:52 AM
  4. multi drill bank/head
    By pinkjas in forum DIY CNC Router Table Machines
    Last Post: 04-07-2009, 08:04 AM
  5. scmi drill bank
    By wcmboss in forum Commercial CNC Wood Routers
    Last Post: 03-23-2007, 03:49 PM
