Hello,
I'm trying to draw a foam wing panel for an RC airplane. So far I have extruded a 2d shape. But I still need to:
1. Taper the end, it's 10" at the root, 7" at the tip.
2. Sweep the wing back - the tip is 5.5 inches back from the root.
3. Add spar holes - remove cylinders from the middle of the wing.
Here are finished ones I cut by hand: Tuffwing-Easy to Fly, Hard to Break RC Flying Wing EPP Foam.
I will be cutting them on a 4 axis wire foam cutter. I have the Wire EDM.
Tips? Thanks!
