well, after many revisions and rethinks, im just about finalised on my ATC spindle.
i ended up blending my needs for a cnc mill, and a cnc router into one package. this is now geared to smaller mills and routers with higher axis speeds.
cant tell you too much of whats lurking inside, but heres the specs:
- 80mm bore (drop in fit for novakon nm145 and tormach 1100 and 770).
- ISO25 taper.
- brushless AC integrated motor with drive, wiring and power supply.
- pc speed control.
- 0.8NM torque continuous with passive cooling.
- 12000rpm.
- manual captured "no bearing load" drawbar.
- P5 grade dual angular contact nose bearings.
- steel nose.
- light weight and super short length of 178mm nose to top.
modular options:
- spindle nose air purge to keep bearings clean.
- air oil bearing lubrication for increased speed to 24000rpm.
- P4 grade ceramic hybrid bearings for top speed of 40000rpm.
- aluminium nose for better bearing heat dissipation (for routers only)
- fan cooled 90mm square mounting block for increased torque of 1NM (for routers).
- water jacket with 1gpm micro pump and radiator for increased torque of 1.4NM (cartridge).
- water block with 1gpm micro pump and radiator for increased torque of 1.4NM (for routers).
- hydraulic "no bearing load" drawbar release.
- tool release air purge.
- remote manual hydraulic drawbar release lever.
- remote air over hydraulic PC controlled drawbar release (ATC).
- rotary union and seal kit for through spindle coolant.
- square 4 bolt or round 6 bolt flanges.
- encoder for orientation and rigid tapping.
i think ive managed to cover almost everything
basically, youd configure the spindle speed and bearings when you order it, then choose the fittings. some fittings can be added aftermarket, like the power drawbar kits. this means you can start with a low price manual tool change option then upgrade when needed.
im trying to keep the price cheap - likely the lowest priced and smallest "milling" grade ATC spinlde out there.
soooo, any thoughts? did i miss anything? im going to link this to the router people as well.
