586,357 active members*
3,586 visitors online*
Results 1 to 9 of 9
    Aug 2005
    20
    Cool Special threads- Determining what it is.
    I have a NSK ball screw I got off Ebay. It is great but I am trying to determine the thread of the lock nut on the end that tightens up on the thrust bearing. The bearing ID is 16mm. The lock nut threads are odd. THe OD is .581" and fits my 32 pitch thread gauge nicely. My problem is I cant find a tap to make a nut for it. I dont have thread wires to measure the pitch dia.
    I have tried to look up the numbers onthe ball nut to see if NSK might have something listed but no luck. I cant even find the series this ball screw is.
    I would appreciate any help in trying to figure out what it is.
    Scott
    Mar 2006
    158
    I would expect that the NSK ball screw is all metric. Furthermore, I would expect that they would use a standard precision locknut on the ends. I would check with you local bearing supply house, or whittet-higgins as they used to have a greta book outlining pretty much all available lock nuts.
    Mar 2006
    2712
    Whittet-Higgins still have their info on the internet. You can down-load it in pdf form.
    Dick Z
    DZASTR
    Aug 2005
    20
    Smile
    Whittet-Higgins is a very interesting website. I came across a .586-32 thread nut which looks like it would be the one to fit from my .581 OD measured dim and it fitting my 32 pitch thread gauge perfectly. I looked on the metric side and found a M15 X 1,0 which is .590 OD but .0398 pitch, Close to the .03125" pitch on a 32 thread. The thought that if it is a metric bearing size good chances are it is a metric thread is probably correct. I am going to get a metric thread pitch gauge and see how well a 1,0 pitch lines up.
    Thanks for all the great help and web site direction.
    Scott
    Mar 2006
    202
    M15 x 0.75 could be a 'standard' but unusual size. M15 x 0.8 might be bang in, if it exists.
    Apr 2010
    Aug 2005
    20
    Smile
    I got the whittet higgins .586-32 ball screw nut and it fit perfectly. With shipping I got it from a local distributer for $7.50. Life is good again.
    Scott
    Jan 2006
    2985
    Sorry I didn't see this earlier. Thats a standard bearing locknut thread. Check here:
    McMaster-Carr
    Matt
    Oct 2005
    2392
    NSK make both metric and imperial leadscrews. (Just thought I would add that)
  1. Determining Latency...Which #?
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 11-25-2009, 11:55 PM
  2. Need help with determining material for screws
    By aaron p in forum Mechanical Calculations/Engineering Design
    Last Post: 03-29-2009, 06:43 PM
  3. Determining the master PCB on 10T
    By guhl in forum Fanuc
    Last Post: 01-23-2008, 08:40 AM
  4. Determining VA load
    By Swede in forum CNC Machine Related Electronics
    Last Post: 04-10-2004, 10:00 PM
