Originally Posted by
MaxTheModder
Thank you for the link. I did already stumbled across them a while ago- but I think their R&P systems are some kind redicoullus.
Their real resolution is 0.13mm per full step - and I never trust that microstepping ratings. even a normal step has a tolerance of +-5% - what is microstepping going to be - +-50%?
Anyway I dont think that I will cut at 1m/s speed. And at low speed the R&P´s resolution is just really bad. Maybe I would have to reduce the speed more with some extra belts and pulleys but $$ and of course : bore belts - more flex
On the other hand it is able to handle only a little cutting force. for example:
the CNCRouterParts R&P system is geard down by 3:1 that means that a stepper with 3Nm force will only be able to hold the rack with an 25mm Dia on the end pulley - only till about 720N. thats too low for me and I am sure that its going to backdrive too often for me. Am I wrong with the 3:1 reduction (I thin I read that in the specs)
Simply mulitply the steppers torque (in Nm!) by 240 and you will get the holding force (only for the CNCRouterParts R&P system)
What do you think? So now I come to the conclusion that R&P is really good for rapids, but they really fail at holding force and accuray and if you want the same accuracy as an ballscrew you would have to gear it down pretty much which results in an high flex on the belts.
One alternative could be a spinning ball nut. The ballscrew would be stationary and therefore would have no whip. The motor would be attached to the gantry and a belt would connect the gears to the ball nut. My techno lc4896 4x8 ft uses this design and is very efficient & sturdy. The techno also uses 50oz/in servos instead of stepper motors. Seems pretty weak but it does work well.
http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
