586,117 active members*
3,606 visitors online*
    Aug 2005
    11
    Dynapath System 10 Monitor Failure
    I have Dynapath system 10 contols on a mill that was just moved by a rigger. When the machine was moved anything that was sitting on top of the control cabinet got tossed inside of it without my knowledge. When I powered up the machine the moniter failed to power up and I found an allen wrench sitting on the PC board for the monitor. It had blown a resistor on the board, but I do not have any manuals for the machine and cannot determine the value of the resistor by it's color code. There may be more wrong than just a blown resistor but I can still read part numbers on everything else should they need replacement.
    If anyone should have a schematic or have a machine with the same controls and can give me the color code i would greatly appreciate it. The resistor number on the CRT PC board is R41. It is located directly under the neck of the CRT on the right front edge of the board when looking at the back of the CRT.
    Any help would be greatly appreciated.
    Mar 2005
    73
    Are you still looking for this info?
    "Fire is cool" -Beavis
