Hello All
First off let me say i love my cnc router, below is a picture of it. What I am wanting to do with it in the future is change the X and Y axis to belt drive. What i would like to do for her Y axis is to turn a drive shaft with two pulleys one on each end pulling her along two belts one on both sides of her similar to the chain drive systems that are out there. Also, I want to pull her X axis back and forth with a belt as well. The motors she currently has are 382 oz/inch and they run flawlessly at 30 IPM with direct drive on 10 tpi acme lead screws. I want to get rid of the leadscrews for distance, noise and maintenance reasons, I also want to speed her up to say 50 or 60 or a bit more IPM with belts but I don't want to lose torque. I am thinking of putting the motor on a drive shaft that gos the width of the machine and on each end of the shaft put a 10 tooth pulley to drive the belts on either side of the machine. I am not in a big crank to do this modification but I am pondering it and need input from all here. Belt drives seem to be Taboo on other sites and I wanted to turn here for more input.
Rob37 PS- The machine has a 3' x 4' table
