586,104 active members*
3,268 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Tuning viper drives Ver 2.8H
    Dec 2005
    29
    I am in process of tuning viper drives on a YCM 30. I am trying to make sense of the values viewed in m.
    m 0000 at power up
    m FEOF at 50 thousand inches
    m FDAA at 60 thousand inches (moved handwheel an additional 0.010)
    This control was a bandit 3 with 500 line encoders and a 5 pitch screw
    Feb 2007
    966
    Those numbers are in HEX. Looks like your encoder is working ok.
    Go one full turn in the positive direction, and use the Windows calculator to translate the HEX to decimal. It will be 4X encoder lines.
    Larry
    Dec 2005
    29
    Thank you for the tip on hex conversion. I have X and Y running at 198 inches per minute and 85 inches per minute on Z. Can you tune the Vipers and run Mach with both programs open? I mean change a viper value, Run mach to check result, then once again adjust Viper.
  1. Question about setting up viper drives.
    By Jackal66 in forum Viper Servo drives
    Last Post: 07-18-2010, 02:10 AM
  2. New 300 Khz Viper drives
    By Larken in forum Viper Servo drives
    Last Post: 04-07-2010, 02:14 PM
  3. Viper 100 drives >c11 bob>computer
    By Tool bit in forum Viper Servo drives
    Last Post: 02-22-2010, 07:02 PM
  4. viper 200 tuning for SEM MT30M4-59 servo motor
    By cwaugs in forum Viper Servo drives
    Last Post: 09-04-2009, 03:01 AM
  5. Selling 3 viper drives and motors
    By DennisCNC in forum Viper Servo drives
    Last Post: 08-12-2009, 10:04 PM
