586,416 active members*
3,180 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Apr 2011
    121
    Some questions on Momus CNC Design
    Bob,
    I purchased your plans about a week or so ago based on your videos and the good reception the plans have gotten. So far, it looks really good.
    I do have a couple of questions though. I should preface these with the fact that I'm an Aerospace Engineer by training and cannot just leave well enough alone (though not well versed in CNC). I'm also cheap to a fault.
    Why all the counterbores? It appears your just putting studs in most, if not all, and it appears to be redundant making the builder have to jig up for counterbores unnecessarily.
    Also, why the use of all-thread in many areas where there are acceptable bolt alternatives? All thread is great for the very long rods, but many other places look like good candidates for common fasteners. You can change a stud and nut out for just a bolt.
    I'm currently looking through the design looking for a bit of cost savings in the aluminum and steel parts. Whether that is buy using alternate materials or by combining parts, I don't know. But since metal is pretty much bought by the pound, combining parts, provided the overall dimiensions don't change, would likely not result in cost savings and may result in more waste material anyway. But, I'm going to try.
    Just trying to understand how these approximately 200 parts go together...
    Michael
    Dec 2006
    202
    Hi Michael,
    Thanks for the good questions. The decisions in both of these were driven by the fact that most people will be hand tapping these holes (at least I was). The counterbores are there to remove some material so you are not tapping the entire thickness of the stock. If you are not 100% straight when aligning the tap into the hole, by the time you are 3/4" deep into the material the tap is going to be hard against one side of the hole. A good recipe for breaking a tap, which is never a fun thing. By reducing the thread engagement, even with some misalignment you shouldn't have a problem. If you have equipment available to tap cleanly all the way through the full thickness of the stock, then sure, go ahead and skip the counterbores. They are an insurance measure for those of use with nothing but a tap and tap handle.
    I should probably put "counterbore" in quotes, since it they don't need a square bottom shoulder. Maybe I should call them "relief holes" or some such thing. You can just run a larger size drill bit part way into the first hole to remove some material. The exact diameter isn't crucial either. As long as it is a bit bigger than the diameter of the threads. Actually, I suppose even if the counterbore were the same 1/4" diameter size as the tap, it would still remove enough material to give some relief against the tap jamming.
    I spent some time carefully marking all holes on the aluminum parts first, so then I was able to drill all of these holes out in one operation. I just set the depth stop on the drill press and went through one part after the other. It just took a few minutes to mindlessly drill all of the "counterbores," and a few seconds of setup time.
    I used studs since they put less stress on the threaded aluminum holes. When a stud is tightened, the primary force is one of pulling, whereas a bolt in that same hole is both pulling and turning against the thread faces. By transferring that force to a steel nut rotating against steel stud threads, you can get much higher clamping force without worrying about the aluminum threads galling or stripping out. If they weren't hand-tapped holes I'd be less worried about this, but in general I do like to put studs into aluminum. it just seems like a good practice to me. Bolts into aluminum make me very worried, unless the required clamping forces are low. Stripping a hole while tightening a bolt would possibly be even more annoying than breaking a tap in a hole, since at that point that part has already been completely finished.
    Since I'm the King of Cheap I can relate to your frugality, so if you figure out any ways to shave any cost, please let us all know!
    -Bob
    Apr 2011
    121
    Thanks for the info. In my field, we rarely have to tap anything deep. In fact, we rarely have enough metal to tap anyway and use nut plates mot always. Obviously not a cheap method.
    I kind of thought that the counterbores were in the design for that reason. Perhaps in the next revision of the instructions, it could be made clear of the reason so the user knows that precision is not required.
    The only possible change I've found yet is that I may delete the z-axis bar that mounts the lead screw nut and router clamp. Against earlier suggestions, I'm going to try to use my Bosch Colt router. A couple of reasons. 1) I already own it. 2) You can get precision collets for it. I don't think the precision collet is necessary, bit you can get collets that mount 1/8 bits without the extra bushing. If I come up with something, I'll share with the group. But, we haven't even ordered material yet.
    A few other questions.
    What is the rational for the difference in height of the left and right X-rails? I would think that mirror images (excepting the stepper motor cutout) would be simpler.
    Why 3/8 ply? Not real common in my experience. 1/4" is common and it appears that 1/4" will suffice in this application. That would let the user just buy two full sheets of ply for the whole project. Never a bad thing to have some extra ply around the shop anyway.
    Again, thanks for your thoughtful plans (even though I seem to question your every design decision ).
    - Michael
    Dec 2006
    202
    Sounds like good arguments in favor of the Bosch to me!
    Yeah, it probably would be simpler. I designed it with the left rail a little bit smaller in size because the bearing forces that are acting on it are less. And also because I really am supremely cheap. By reducing it in size it saved a few cents on metal cost, and a little bit of shipping weight (I was ordering from online metals). So the smaller rail then resulted in the slightly taller dimension of the base to compensate.
    This has come up a little bit in the first Momus Design thread that was started here on cnczone (the one in the main DIY woodworking forum). Around where I live it is a very common plywood size. It is in every Home Depot, Lowes, etc. So I used what was the ideal thickness plywood for each area of the machine. It wasn't until I started getting feedback from builders that I realized that plywood availability seems to differ considerably by geographical region. I've had a few guys who couldn't find any 3/8" ply of any sort in their areas, which totally took me aback. Luckily, the base construction isn't that complicated, so with a little careful studying of the exploded view drawing it should be obvious where to change a few dimensions if you need to use a different thickness. I think one guy ended up just building the whole base out of 3/4" ply. I think if it were me, instead of dropping down to 1/4" as you suggest, I'd go up to 1/2" or even 3/4", at least for the top skin (part F in the exploded view) as it is the bed area, and the sides of the machine also attach to it. The other parts should be fine if they are 1/4"
    -Bob
    Jul 2007
    36
    Smile Z axis thrust
    hi all, I have now spent many hours looking at the plans and on occasion totally confusing myself. Still I think now I have a handle on the beast.
    I have made both rails the same and in my case down here in NZ I have had to go metris so we have the 1.25" angle which remains same but rails (304 stainless) are 40 x 6mm. Unfortunately such rails ase guillotined from plate by the European supplier and seemingly run through a routing/milling operation to meet straightness standards. this may not be "flat" enough and I may have to surface grind both edges of each bar. at this point have cut drilled and tapped and after assembly will set up on surface plate to check out how good it is before making choice. A friend also making a self designed machine for metal has just completed setting up his z axis and has it to 5 thou top to bottom of travel which is fairly impressive.
    Anyway a question I had was about the fact that there is no thrust bearing assembly for the "Z' drive with the coupling and the stepper taking the load.
    Is there any issue with this???
    My Y gantry is RHS steel 75x40x3mm which I hope to lighten out by cutting out some triangular holes top and bottom. At moment it is already made and drilled.
    Rayna
    Dec 2006
    202
    Yes, it isn't the ideal situation to have the stepper taking the thrust load. I decided to give this setup a try and see how it worked. So far I haven't had any problems. We'll see if it hurts the longevity of the motor bearings. A thrust bearing on the Z leadscrew would be nice, but it would also take up some more room. If I could come up with an inexpensive and elegantly compact solution I might add it in. In the meanwhile, I haven't had any problems with the current arrangement. I think it might depend also on what kind of work you are doing with the machine. If you are doing primarily full 3 axis work, like cutting highly contoured surfaces with lots of up and down Z movement, then the Z might want that bearing plus some other mods as well. Like a multi-start acme screw. Any good thoughts on how a thrust bearing could be incorporated?
    -Bob
    Apr 2011
    Quote Originally Posted by Michael In Cali View Post
    - Michael
    I only suggested not to use the Bosch because of the substantial change in the design to integrate it. But by all means go for it!! Since I am done messing around with creating new clamps for the Rigid 2401 router, and I was initially going to use the Bosch Colt palm router, I will make up some clamps for it and give it a try. i prefer the Bosch over the Rigid any day. If I will try to get some clamps cut and mount the Bosch between tonight and tomorrow. I will also send my mechanical drawings to Bob so he can incorporate them into future revs of the plans which will give this design more potential and maybe help people save a few bucks if they already own a specific router model.
    Billj
    May 2010
    118
    Possible thrust washer for Z solution
    Bob, et-al;
    I was thinking about a thrust-washer solution for the Z myself. What if one were to raise the motor just enough on stand-offs to allow room for a shaft collar, thrust washer, and 1/8" support-plate on top of the current Z axis mounts? Put a thrust washer and second collar below the plate and voila - no axial load on the motor. (I just happen to have all of the above lying about from the design I no longer plan to build)
    I figure stand-offs no more than 3/4" should be plenty, and 1/2" might be enough. The only issue I can see is a possible clearance problem with the lid?
    This would have the added benefit of eliminating the need for relief arcs in the Z axis motor mounts.
    I think I have some 1/8" plate and assorted nylon stand-offs in the shop. I will try and mock it up when I get the Z motor mounts done and post some pictures for your thoughts. The nylon mounts would be for testing only, replaced by aluminum if it actually works.
    Regards,
    Randy
    Apr 2011
    Bob,
    Michael
    You kind of answered your own question initially...
    I am not speaking for the designer just out of experience of building this design and also by some of the notes he had in the plans.
    I initially thought the same as you for counterbores and though maybe a lot of cap head screws would be used, but not the case for the cap head screws although I did change the studs in the four main carriage bolts to 1/4-20 stainless cap head screws and am in the process of changing them to 5/16-18 capheads to make it sturdier.
    First, the plans are designed for a beginner with not many tools, with that said...the counterbores have two functions. I believe it is stated in the plans that they were used to lessen the depth to tap and once you start building they act as a depth guide for the studs. Granted they are not at all neccessary but do not hurt the design at all either.
    Use of all-thread...
    Again, this is a beginner to intermediate project and also attempts to use readily available, easy to find hardware. all-thread can be located at just about any hardware store in existence. Using alternate hardware like cap head screws for instance can be difficult to find locally especially in some of the sizes required for the build. Yeah I know there's the internet and everything is available but that adds shipping, etc. and sometimes it is just easier to go to the store to get what you need These plans give a good starting point to create a good machine, as many of you will do and I did, once it was built I changed things around to be easily servicable and to get rid of some of the studs.
    Cost savings and alternate use of materials...
    Sure you can change materials for some parts, sure you can shave a few bucks here and there. And if you have the right equipment you dont have to get the exact pieces of metal from the BOM. I had a few pieces like this and having a mill i was able to use some of the scrap pieces in other areas. But, this design is trying to eliminate having to use and specialty equipment. When it comes down to it we will all use our own experienceto get the job done accurately and quickly, not a single one of these machines will be built the same way but in the end they will all look similar.
    FYI...I spent less then $200 on metal and that was with some extra "oops" pieces.
    Hope this helps a bit!!
    Billj
    Apr 2011
    oops, ignore my previous post :)
    sorry, had the older posts sorted first and just realized after all that typing that the questions were already answered
    Apr 2011
    121
    Quote Originally Posted by bjesson View Post
    No problems. Still some good info to be gleened.
    Dec 2006
    202
    Randy- if you get a mock-up of this done at some point, please post a photo. The cover clearance issue could be dealt with easily enough with some minor mods.
    -Bob
    Apr 2011
    121
    Cover and front flange
    Regarding the cover:
    I plan on not making the cover or the front flange until the unit is built and tested. With the possible change to the Bosch router I figure I'll just wait and see how it goes.
    I do plan on building the cover for sound and chip collection. I plan to add a vacuum system as well, and that can change the cover shape as well. I might make it less of clear materials for additional sound deadening. A sliding cover with window seems like a cool idea. It would look more like a professional machining center.
    Feb 2011
    what is the circumference of timing belt pully
    i think so with 1/16 micro step the machine is capable of providing better accuracy.
    i have plans and now converting them to metric
    I am replacing all 1/4 to m6 and all 10-32 to m5 or m6. Is it okey ?
    I am doing a round figure in mm like 152.4 converted to 152 mm
    help me more if you can in convertion.
    parallel_lines if you need my metric plans i will be happy to provide them to you
    Dec 2006
    202
    Karandex,
    I just started a new thread for builders of metric machines, so I answered a couple of your questions over there.
    The 1/16 microstep might not get you much more accuracy, as the limitation will most likely be in the accuracy of parts like the cold rolled steel rails, the belts, and the leadscrew. The electronic drive resolution is already smaller than the manufacturing tolerance of these parts.
    -Bob
    Feb 2011
    what is accuracy counted by you ?
    i think dont think of those tolerance will count. have you tried doing it. i am thinking of using this machine for engraving,pcb isolation routing and 3d printing.
    3d printing can be dont easily.
    Dec 2006
    202
    Ok, here are my definitions:
    Accuracy- the discrepancy between where the computer thinks the tool tip is positioned in space, vs. where it actually is. For example, lets say the gantry rail has a curve to it. Lets exaggerate and say it is a big, visible curve, where the center is bowed out by 10mm. If you move the carriage to that area, the digital readout is going to say it is in a certain position, but in reality it is 10mm away from that spot. It is inaccurate. Being able to move the motor in smaller steps will never fix that physical problem with the metal, and it will still be inaccurate by 10mm.
    Precision- Also called repeatability. The ability to come back to exactly the same position when instructed by the computer. So in the above example, even though the position in the center of the gantry is inaccurate, the machine might still be able to come back to exactly that same position over and over again. It is still 10mm off in its accuracy, but it has high precision. Things like backlash, play in the bearing adjustments, etc. can effect precision. So a finer microstepping may increase the precision of the system.
    Obviously the ideal situation is to have both high accuracy and high precision. But making improvements to one area and not the other will most likely not result in an overall improvement to the system.
    -bob
    Feb 2011
    still you didnt answer my question
    what is
    accuracy
    resolution and
    precision or repeatability
    measured by you
    we would love to see some job done by your machine or more videos
    Apr 2009
    5516
    Quote Originally Posted by karandex View Post
    what is
    accuracy
    resolution and
    measured by you
    karandex,
    I believe Bob has a few videos on YouTube; have you seen them? bjesson1 has pics of his build on the first thread!
    As far as resolution, since it's direct belt drive, regardless of the pinions you use, most steppers have a step of 1.8 degrees, or 200 steps per revolution. Your mechanical accuracy is this .005". You can use microstepping to increase the resolution and give you smoother movement at slower speeds. You could also get a stepper with .72 or even .36 degrees/step, but they're expensive and use dedicated drives.
    Watch the video where Bob cuts aluminum, you'll see that the repeatability is pretty darn good. If it wasn't you'd see stair stepping on the milled edges.
    You have to remember this is a belt drive system, so a lot of the repeatability has to do with the quality of the belts/pulleys you use as well as how good you made the linear rail system.
    My machine (haven't built this one yet) also has a .005" resolution, and with 8x microstepping, I get details as fine as .002", so I guess microstepping technology has come a long way. That said, repeatability is way more important.
    Trust me: unless you use precision ground ballscrews and linear rails, servomotors, and a commercial spindle, and make your entire machine out of cast iron, it would be very difficult to hold .001" consistently, let alone .005". There are guys out there making PCB's with MDF routers, and 3D printing is done on machines made of MDF and/or threaded rod and belt drive. The MOMUS design is far more robust than either!
    Apr 2011
    what is
    accuracy
    resolution and
    measured by you
    Here's the link to the original sub forum that I posted most of my build pics in and gave reviews along the way. Pages 4,5,6,7 have most of my pics and reviews. All my current posts of the router clamps I have been cutting have all been done using this CNC machine.
    http://www.cnczone.com/forums/diy-cn...cnc_plans.html
    Billj
Page 1 of 2 12
  1. Welcome Momus Builders
    By kemper45 in forum Momus Design CNC plans
    Last Post: 02-01-2012, 07:44 PM
  2. Momus Design CNC Plans
    By iplay1515 in forum DIY CNC Router Table Machines
    Last Post: 09-27-2011, 05:46 PM
  3. Design questions
    By elz in forum DIY CNC Router Table Machines
    Last Post: 04-21-2009, 04:37 AM
  4. MCX Design questions
    By Shotout in forum Mastercam
    Last Post: 04-02-2007, 05:30 PM
  5. Design Questions
    By hani_a in forum CNC Machine Related Electronics
    Last Post: 07-21-2006, 08:45 PM
