586,061 active members*
4,342 visitors online*
Thread: A BIG PUZZLE
Results 1 to 1 of 1
    Mar 2010
    Question A BIG PUZZLE
    I need an opinion. Ive attached a piece, the plate from a stamp. There are 4 dimensions there. The problem is that after machining on a HURCO (3 axes) using PRO Engineer 4 for programming, the dimensions, starting from the start hole, had displacements in an arithmetic progression. Like instead of 47 it was 47.2 mm. Then , instead of 80.6 it was 90. Then 114 it was 114.6. We couldn't figure it out because the other holes are ok after measuring. If anyone has an idea of what the cause may be or it has happened to him please leave a reply.
    Attached Files Attached Files
  1. 3d puzzle dxf files
    By chadwiggan in forum Machine Created Art
    Last Post: 11-23-2017, 05:16 PM
  2. Puzzle Pieces
    By ccroyscuba in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-13-2008, 04:43 AM
  3. 3D Puzzle software
    By wlloydda in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 08:16 PM
  4. G50 Puzzle
    By NID in forum G-Code Programing
    Last Post: 03-12-2006, 01:26 AM
