586,100 active members*
2,713 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Z axis is going crazy! "Mach Blue screenset"
Results 1 to 7 of 7
    Mar 2011
    215
    I've been using my Zen 12x 12 with Mach 3 for a while now with no issues. All of the sudden I'm running into issues where the Z axis wants to go the wrong direction at times.... One specific time it does this is during the Z axis calibration (Z- button). I'm using the "MachBlue - probing big tex ver3.2" screenset that has the touch test on the Program Run screen.
    I actually think my problems started when I tried to run the "Initial Zero Setup" script found on the Program Run screen. It did not want to work correctly (reversed Z axis) so I stopped it. ever since then I've had problems with the Z axis going crazy. It would go threw the calibration touching the plate, going up a bit then down slowly till it touched again, and instead of going Up as it should it plummets down into my touch plate!
    Has anyone ran into this type of issue before? If so please help me get my machine behaving correctly again!
    It seems as though I can cut some stuff when I manually zero the Z axis but just a minute ago I tried cutting a piece and 1/2 way threw the Z decided to bore all the way strait down... The DRO actually changes to a much higher positive number making the machine think it is way high when its not. I'm cutting slow so its not a skipped steps issue... What is going on!
    I had an issue when I tried to home my Z axis, instead of moving toward the switch, it would move 1" away from the switch.
    I had to create a new profile from scratch to get it working correctly again.
    Mar 2011
    215
    I would be willing to give this a try if I only knew how to do it. Where do I create a new profile in Mach3?
    Double click on the Mach3 loader icon, or Mach3.exe from explorer.
    Mar 2011
    215
    Well that was easy enough. Before getting your reply I tried using the restore function. Went back to spots and the calibration thing seems to be fixed. I couldn't test the cutting part out to well because I'm trying to cut some 3/8" plastic cutting board (Building a 24" x 48" machine) but my bit keeps melting the material ruining the piece every time... I'm currently using a 1.8mm end mill. It seems to go longer without clogging at slower spindle speeds but it still clogs eventually... Maybe a larger bit? I should start a new thread but if anyone has any suggestions for the cutting issue it would be appreciated as well
    Re: Z axis is going crazy! "Mach Blue screenset"
    Quote Originally Posted by Claytonc View Post
    you need to increase chip load: decrease spindle speed, increase travel speed, change to larger diameter endmill, endmill with fewer flutes. Or some combination of the above.
    1227
    After nine and a half years,he might have figured it out.Or found other interests.
  1. "Mach Pro 7" - New Screenset!
    By mikemaat in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-01-2014, 03:36 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. How crazy is this idea for an X2 "staged" CNC conversion?
    By mhackney in forum Benchtop Machines
    Last Post: 12-27-2012, 12:14 AM
  4. Plasma 4' X 4' "How much can you haul in a blue truck"
    By 555e in forum Waterjet General Topics
    Last Post: 07-27-2009, 01:20 AM
  5. My "Crazy" high speed spindle test
    By SScnc in forum Benchtop Machines
    Last Post: 04-21-2009, 01:16 PM
