587,070 active members*
3,328 visitors online*
Results 1 to 6 of 6
    Mar 2011
    1/4" aluminum set up
    what are some basic machine set up for 1/4" aluminum? i have a miller spectrum 1000 plasma
    Mar 2009
    924
    Quote Originally Posted by RHmotorsports View Post
    I am not 100% sure but the spectrum 1000 is made by Hypertherm, you could follow the cut charts from the powermax 1000. It is a 60 amp machine.
    The Hypertherm cut charts are spot on usually. I have never cut aluminum, so I can't offer much help here.
    WSS
    www.metaltechus.com
    Jan 2008
    2247
    The torch is made by Hypertherm...but it is a bit different from the Powermax1000 torch...however the cut charts (under mechanized torch cutting) will get you in the ballpark.
    Jim Colt
    Mar 2009
    4
    Hypertherm Duramax on Miller Spectrum 1000
    Do you know,if retrofited correctly, a new Duramax torch will do on a miller spectrum 1000? I'm asking this because in Mexico where I am is kind of hard to find consumables for this machine, and cut quality is worse compared to an Old Hypertherm Max70 and an Esab PCM-875 cutters.
    Jan 2008
    2247
    I really cannot answer the question as we have never retrofitted a Duramax torch on anything but a Hypertherm system. Chances are that due to the newer torch technology...that it would work much better than the original torch.
    Jim Colt Hypertherm
    Quote Originally Posted by colorvp View Post
    Mar 2009
    4
    Duramax torch on miller spectrum 1000
    Hello.
    I have ordered a Duramax torch for a powermax65, and I installed in my cnc plasma cutter. As I commented in this thread, I have an spectrum 1000 that I always had trouble finding consumables. The torch works fine, since is very similar with original from miller. Now my plasma is dead not because of the torch, but I believe for the total runing hours. One big capacitor blow off, I replace both of them with new ones, but it still have some trouble. Maybe I should create a new tread to comment this.
    greetings everyone.
    Alfonso
  1. DIY 96" sheet metal bender- Pan/Box, Straight Just for .063" aluminum
    By diyengineer in forum Bending, Forging, Extrusion...
    Last Post: 11-25-2011, 04:37 AM
  2. Replies: 2
    Last Post: 05-01-2010, 01:41 PM
  3. Replies: 6
    Last Post: 06-24-2008, 01:14 AM
  4. Making brackets; bending 1/4" x 3" aluminum flat stock
    By guru_florida in forum Bending, Forging, Extrusion...
    Last Post: 06-08-2008, 11:48 PM
  5. "Open Source" Aluminum Extrusion Profiles
    By devers6 in forum DIY CNC Router Table Machines
    Last Post: 12-18-2005, 12:04 PM
