586,471 active members*
3,586 visitors online*
Thread: Face milling
    Feb 2011
    100
    Face milling
    Does anyone know a easy, none time consuming way to do simple one off Face milling on a CNC mill.
    Mostly I do drilling and pocketing of castings but I get people coming in all the time for simple milling operations but setup is just too time consuming.
    What Id like to do if possible is turn on the spindle and use the MPG for positioning.
    Bridgeport VMC Fanuc 21i-MA
    Feb 2011
    100
    I figured it out. Bad key....
    Aug 2009
    684
    See if its worth getting manual guide i activated. Makes face milling any shaped part a piece of cake. Hell, it makes everything a piece of cake.
    Other than that, you could write a macro program in which you define the opposite corners of the area you want to cover, finish Z position, stock, cutting depth and stepover.
    DP
    Feb 2011
    100
    This machine is almost always used for the same few tasks. I wanted to use it for face milling other parts. I have a macro but it didnt work. Ended up being a control issue with a bad contact on a button. Cleaned it and it works fine now.
    I dont think this machine can use Manual guide i.
    Apr 2006
    3206
    This thread dealt with face milling..
    http://www.cnczone.com/forums/genera...ill_usage.html
    As to programming, a macro would be ideal, with prompts written into the code so all you need to do is punch in the X,Y values, depth steps, feed and speed if you're not using the same cutter every time or running different material.
    Keep in mind the importance of entry and exit paths if you're running carbide insert tools!!
  1. Face milling
    By TURNER in forum OneCNC
    Last Post: 01-20-2011, 08:44 PM
  2. Face milling help
    By thedave in forum Benchtop Machines
    Last Post: 09-07-2010, 08:22 PM
  3. Small face milling bit
    By rnr107 in forum Want To Buy...Need help!
    Last Post: 03-22-2010, 04:27 PM
  4. Face Milling Delrin
    By Shane39 in forum MetalWork Discussion
    Last Post: 11-07-2008, 08:55 PM
  5. Help with face milling...
    By peter.blais in forum MetalWork Discussion
    Last Post: 09-24-2006, 07:20 PM
