instead of die cutting, is it possible to cut with a cnc router; if so what kind of router bit would you use? any help would be greatly appreaciated, thank you, brady
we offer CNC cutting machine, can cut the counter of sign board instead of die cut. Cut the shape in few minites after import the design into the cutter. You can know about it in this link: cutting machine , Or you can contact withme directly.
This for wood?is it possible to cut with a cnc router; if so what kind of router bit would you use? any help would be greatly appreaciated, thank you, brady
Your question is rather vague? but a CNC router with straight bits will cut out whatever you are cutting out? the thinner the bit is better with two cutting edges.
