586,051 active members*
3,712 visitors online*
Results 1 to 8 of 8
    Dec 2004
    312
    blower for plasma/torch cfm??
    i realized having a water table setup with my design is out of order.. so im going to have suction system using blower not too sure whats its called..
    its for a 5'x10' table and i am planning on have 2 seperate suction area so 5 by 5 section and 5 by 5 section maybe just have one motor with a t setup or 2 motors
    Aug 2004
    2849
    You might look at having a hood over the cutting area...something you can raise and lower and attached to it would be something like the dust collectors used for home wood shops...something in the range of 600 to 1200 CFM. You could have the dust collector some distance away from your plasma table.
    Dec 2004
    312
    i did considering putting a shop vac line or something right beside the torch/plasma but i think it might will affect the cutting quality? i dont mind having a scoop under like those torchmate or soemthing... and quite few big torch machines have those system.. so i guess those system works well?
    Oct 2005
    1238
    DanOSB
    For your plasma table fume removal, what system did you end up using?
    WT
    Dec 2004
    312
    i ended up doing water bath under the cutting area
    Oct 2005
    1238
    Thanks DanOSB
    Hope the water bath works well for you.
    WT
    Dec 2004
    312
    so do i im about 2/3 completed wtih my setup.. www.ubcustom.com/cnc (or u can look at my buildup thread
    Oct 2005
    1238
    Quote Originally Posted by DanOSB
    DanOSB, Thanks for the link. Great photo record of your build.
    WT
