587,070 active members*
3,441 visitors online*
    May 2011
    7
    Mach3 Configuration will not save ????
    OK, 100% new to any CNC, & mach program. I have read up on all I'm working with, & have managed to get my setup working.
    My problem is:
    I open Mach3 (trial version) & can set & configure everything to work great, but, upon closing & reopening, I lose all adjustments.
    Have tried the following:
    1: "Save Configuration" under the config menu
    2: tried renaming one of the "xm#" files in the "past xml files" folder
    And, just to clarify, I am working with a secondhand system. The PO had a working XML file that I'm working with, & upon close & reopen, I lose any changes.
    Any and all help is greatly appreciated. I've done several searches, & haven't found anything of this nature.
    edit:
    Also to clarify, I'm trying to change settings for:
    1: Steps per unit
    2: slave axis
    Is the .xml read only?
    May 2011
    7
    I cannot say 100% for sure no. But I don't think so.
    I even created a new profile (using original as clone from) & tried with it, so I really don't think that would be it. But will definitely check that.
    Apr 2004
    5739
    If you're making changes in the Motor Tuning
    dialogue box (which is where you set the steps/unit) you need to hit the "save axis" button for each axis you change, or it ignores the changes. (This is easy to miss - don't feel bad...)
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    May 2011
    7
    Solved
    Thank you Andrew, though that did initially get me, that was not the problem in this case.
    Ger21 actually called it. As I said, I'm working with a file someone else had originally created, & it was set read only.
    On a side note, I also double checked the new XML I created using the original as a clone. Evidently the read only status followed through, the only difference between the new & old was the title. I thought that a little odd.
    Thank you both for the assistance, off to learn some more.
  1. Home/Limit configuration in Mach3
    By ranju in forum DIY CNC Router Table Machines
    Last Post: 11-10-2012, 11:21 AM
  2. Mach3 tool table save / print ?
    By Scott_M in forum Tormach Personal CNC Mill
    Last Post: 08-03-2010, 12:27 AM
  3. Mach3 Configuration Shopmaster 2000
    By eirigoyen in forum Shopmaster/Shoptask
    Last Post: 04-09-2010, 07:50 PM
  4. Mach3 for Maxnc 5 configuration
    By wushu2266 in forum Mach Mill
    Last Post: 07-06-2008, 06:12 PM
  5. Can someone Please help me how to save my mach3 configuration as a xml file
    By JaiTalkin in forum Machines running Mach Software
    Last Post: 06-04-2008, 05:29 AM
