586,494 active members*
2,348 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
Results 1 to 20 of 20
    Mar 2011
    There is an ANNOYING alarm that comes up on Mazak mills that NOBODY I have EVER known, knows how to clear without a minimum of 20 minutes of experimental button pushing in pure desperation to get the machine back up and running again.
    The alarm occurs when an operator presses the "Reset" button while the machine is in the process of performing a tool change.
    For myself and many others, hitting the "Reset" button is an immediate and instinctive reaction to the realization that there may be a problem somewhere or that the program or other data may have been inputted incorrectly to which it is necessary that the machines operation be terminated quickly from running.
    Now I know that the ultimate solution is to NOT push the "Reset" button during a tool change, but sometimes instinctive reactions take control and I then get stuck with 20 minutes of time wasting and lots of cussing to clear this alarm which I (and others) clear only through random button pushing to which finally hitting the magical combination of buttons to clear it.
    I would SO GREATLY APPRECIATE it if ANYONE here can PLEASE tell me the specific and correct way to clear this alarm on the Mazak CNC mills. It is not just limited to one model or version of Mazak CNC mill as it has occurred exactly the same on several different model Mazak mills. It is SO gosh-darn frustrating!! Please help!!
    Thanks in advance.
    Apr 2010
    45
    many machine tools act like that it is because it looses the turret position when you press reset. and you have to re-establiss a known turret position.
    Mar 2011
    Quote Originally Posted by NICK1945 View Post
    Yes, I do believe this is the reason for the alarm. BUT the million dollar question that I am seeking is HOW does one quickly establish a known turret position on the Mazak? HOW exactly does the operator do this to get up and running again to clear the alarm? What specific steps are required to do this other than just pushing random buttons for 20 minutes in complete desperation?!?
    Does Mazak even know the answer to this? I am starting to wonder being that NOBODY thus far seems to know the answer to this one!! Nobody!!
    Dec 2003
    24223
    Quote Originally Posted by Mill&Lathe View Post
    It might be helpful if you stated the machine model as requested?
    Also have you checked for the maintenance M codes for individual T.C. operation?
    Al.
    Albert E.
    Mar 2011
    Al.
    Oops, forgot about that, sorry. Its a Mazak VariAxis-500. THANKS!!!
    Will also check for maintenance M codes also but I think the others have already done this and there is nothing that helps. Thanks.
    Dec 2003
    24223
    The T2 T3 lathes had a outboard PLC for the tool changer, I don't think the mills had it.
    what model is the controller?
    Many have a set of M codes that act on single actions allowing you to get it back in sync.
    Al.
    Albert E.
    Oct 2005
    672
    As Al The Man said, Mazaks use Mitsubishi controls which put a lot of the tool change functions outside the control. I have Dynamechtronics mills with Mitsubishi M3 controls and get an alarm if Reset is pressed during the tool change. Something in the PLC never gets the "finish" signal from the external tool change device (or the ATC macro) so the PLC alarms out. On my mills, it's about a 20-30 second delay before the alarm appears. Once the alarm appears, I have to power off the control to clear it.
    If I realize my mistake fast enough, I can jump into MDI and command another tool change before the alarm appears.
    Dec 2003
    24223
    I am not sure if I have the maintenance manuals for those, I won't be able to check until tomorrow.
    Al.
    Albert E.
    Mar 2011
    Al.
    THANKS Al_The_Man!!!!! I really appreciate it!!!!!!!!!
    Mar 2005
    988
    The quick way to clear the alarm is to simply satisfy the ATC condition for where you got it stuck at. The Variaxis is a simple tool changer. Get famililar with the ATC Maintenance page. I can clear any ATC alarm in seconds (unless something mechanically very bad happened).
    The best way to get familiar is to go through a tool change cycle using the Maintenance page from start to finish (you'll also need to use the Tool Clamp/Unclamp button midway). It's a simple matter of 'order of operation'. No matter where/how it's stuck, look at where it's stuck relative to the order of operation and move forward from there.
    There are certain M-codes for maintenance but not all of the actions have them. Since you're in the Maint page anyway, might as well just use the buttons.
    It's just a part..... cutter still goes round and round....
    Mar 2011
    Quote Originally Posted by psychomill View Post
    This is what I have seen operators attempt to do many times to clear this type of alarm but in actuality, it never goes as easy as you are explaining for some reason!
    For some reason it seems that the machine becomes stubborn under such an alarm condition and it doesn't want to cooperate to operator commands which is why the solution always ends up being 20 minutes of button pressing in random combinations until a certain combination eventually wakes it up or forces it to cooperate.
    I have never seen even veteran operators clear this type of Mazak alarm as easy as you suggest. I am so very curious as to what you specifically do to get it resolved in seconds as you say. I get the gist of what you are saying, but again, that doesnt seem to work for anyone.
    For example, say that you had T24 pulled up which was used for edge-finding your part and then finished setup and was ready to run a program. So you now press the cycle start button to begin the program which calls up T1. So T1 comes out and just before the tool door cover shuts and while while the cycle start button is still flashing green and tools still cycling, you hit reset. What specifically do you press now and in what order? This will be nearly earth-shattering to discover a way to clear this in seconds as you say you can do. Thanks.
    Mar 2005
    988
    So given this condition, the only thing you need to know is the other side of the door status. The ATC maintenance page is simply a 'step by step' process of what happens automatically in a program or MDI. You simply need to visualize in your mind at what point of the auto cycle did the operator stop the machine at. This is your start point on your maintenance page.
    The simplest fix if the tool is in the chain already but indexing is to simply go to your magazine control panel and jog the tool chain 1 pocket to complete an "index" increment then simply restart your program. If the chain is stopped in between pockets, the machine will not start.
    Now if the tool is still in the ATC shifter or the change arm, you need to start from that point of the the ATC cycle to do one of 2 things.... Complete the cycle or bring the tool back to the Next Tool position. Sometimes it's quicker to bring the tool back to Next Tool position and restart the program from there. Especially on dual chain machines.
    To describe all of the instances would take too much print here. Do what I suggest though... spend a half a day and step through the entire ATC cycle only by using the Maint page. This will familiarize yourself with each step and buttons. It's worth it to do this then to sit there and cuss at it each time later. Take the time to learn it.... it's cheaper on the long run...
    Also, learn that on the MDI function, you may need to update the tool numbers for the one in the spindle or Next Tool. If this doesn't match with how you "fixed" it in Maintenance, the machine won't restart correctly either....
    Mar 2011
    Thanks a lot for your help psychomill, I really appreciate it.
    Jul 2006
    19
    Many CNC mills--not just Mazaks--will throw alarms when hitting reset during a tool change.
    Simple solution: Hit single block or feed hold. Get in the habit of having your hand on the feed hold button.
    Feb 2007
    198
    When I was at Mazak, my role was customer support focusing on using the machine. What I always told people on my post install training trips is that the worst thing you can do is hit RESET IN THE MIDDLE OF A TOOL CHANGE! It may be necessary to abort a tool change, but you should avoid it at all costs. Simply because restoring the proper state to the TC is a challenging series of steps that involve MDI and manual operation in rigid sequence.
    On many modern Mazaks, like Variaxis and Integrex and a few others, they even rivet on a aluminum plate "cheat sheet" with the tool change sequence on it. Mazak has a bunch of internal procedure write ups on this subject, which the factory guys use so much they have it memorized!
    PS - I know of one former Mazak guy that got his hand seriously hurt when he was called in to fix a stuck tool changer. His injury could have been avoided if there was good debriefing between him and the customer. I think there was no communication at all, hence the smashed hand and subsequent visit from OSHA.*
    Just some comments... FWIW.
    -90% jimmy
    *I informally track CNC machine injuries. I was personally acquainted with two people that died in CNC accidents. One in the early 80's and the other only a few years ago. A female grad student at Yale died in the machine lab a month ago. Her hair got caught in her manual lathe. Weeks from graduation.
    Oct 2011
    qt250 turret crash .... turret is out of line what broke???? still locks and rotates
    Dec 2013
    4
    Re: Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    Thought I would add to this. There is a rb parameter that you can change that controls how the atc reacts upon reset. You can set it to finish what it is doing even when reset is pressed during atc.
    Jan 2014
    this obviously wont be helpful to you now but alls i do is usually manually unload the tool that has been loaded into the spindle and then go round to the back of the machine manually move the tool carousel a couple of times then go back to the screen and call out the probe usually allows me to then start again.
    Mar 2017
    5
    I hope that you now has realized that a good operator doesn't hit RESET or EMERGENCY buttons, on less there is really danger happening if not.
    Instead turn FEED down to second lowest number, things will then move slowly, and nothing happens, when toolchange is completely finished in the correct way and changed tool is back in the chain, then hit SINGLE BLOCK, then you can hit RESET.
    There is also a DRY RUN button that slows things down, a button to use on first part, to avoid crashes, you control feeds with the percentage button.
    Jun 2022
    28
    i know this is an old thread but how did you resolve your 256 alarm my issue is i can't home the B axis on the integrex i can jog it but i can't home it this was after a battery replacement on one of the servo drivers
  1. MAZAK ALARM 404
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-18-2016, 07:44 AM
  2. Mazak H-500 Alarm
    By newguy81 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-17-2013, 06:50 PM
  3. Mazak QT 15 Alarm 14 Drive alarm z axis
    By Rodent73 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2013, 01:21 PM
  4. Mazak M2, 448 alarm?
    By Wimbleball in forum CNC Machining Centers
    Last Post: 10-23-2009, 10:46 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
