586,392 active members*
2,827 visitors online*
Results 1 to 1 of 1
    Sep 2010
    Write Wizard - Thank You German Bravo
    It seems we are quick to complain when something doesn't work and slow to praise when it does.
    I machine a fixture made for the locksmithing industry. The first units were manually fabricated on a standard mill. The part # etc. was manually stamped. Not pretty.
    Having acquired a Novakon NM-200 to produce these parts proved a blessing. The precision and overall finish improved manyfold. Then I discovered the Write wizard and it proved to be the finishing touch. The engraving added a distinctly professional look. Considering that it generated 9 pages of code for under 20 characters, I can't see me ever attempting that manually.
    Have attached 2 shots, not the greatest photographer
    A sincere thank you to German Bravo.
    Attached Thumbnails Attached Thumbnails plug holder 004.jpg   plug holder 007.jpg
  1. Mach 3 write wizard
    By Jig Maker in forum Engraving Machines
    Last Post: 03-02-2011, 07:14 PM
  2. Write Wizard Help!
    By ibuildstuff4u in forum Mach Wizards, Macros, & Addons
    Last Post: 08-12-2009, 06:25 AM
  3. Write wizard...To many numbers
    By Scott_M in forum Mach Wizards, Macros, & Addons
    Last Post: 02-09-2007, 07:14 PM
  4. Mach 3 Write Wizard
    By rweatherly in forum Mach Wizards, Macros, & Addons
    Last Post: 12-18-2005, 11:25 PM
  5. Write Wizard Problem
    Last Post: 11-13-2005, 02:17 PM
