Specifications VTC6070
Max. swing dia. mm 800
Max cutting length mm 700
Max cutting diameter mm 600
Spindle speed range r/min 50-1000
Main motor power kW 22/30
Chuck diameter inch 21
Rapid traveling speed of X-axis m/min 10
Rapid traveling speed of Z-axis m/min 15
X-axis travel mm -50,+650
Z-axis travel mm 700
Machine weight kg 10000
Overall dimensions(LxWxH) mm 3640x2510x3438
Standard Equipment:
- FANUC
- 0i-TD
- αP50 servo main motor 22/26 kW
- Two axis α servo motor
- NSK bearing
- Boschrexroth linear guideway
- 12″ solid hydraulic chuck
- 8-position hydraulic turret
- Chip conveyor
VTC6070 - Available in stock
