586,116 active members*
3,387 visitors online*
    Sep 2010
    76
    Using a ballscrew on the Z axis
    Hi all
    I am about to start on a new build, previous units have been threaded rod, then ACME, now I have the budget to go with ball screws.
    From my reading I find that ball screws are not self locking, so if used vertically gravity will pull the router head down and the screw will free-wheel (assuming of course the motor is not powered)
    Am I correct in this understanding and if so what can I do about it ?
    My thoughts are:
    • Dont use ball screws, use ACME for Z
    • Make sure the motor is always powered, a bit hard
    • Use some sort of electric clutch or free wheel inhibit
    Any advice please ?
    Sep 2010
    717
    I have a 5mm pitch ballscrew on my Z axis. No problems when powerd off, the stepper has some resistance which is enough to keep it from moving, at least in my case. The weight of my Z axis is a bit over 10kg.
    I think it might be a problem if the pitch was 10mm for example..
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    Mar 2006
    2712
    Motor with a brake?
    Dick Z
    DZASTR
    Apr 2010
    Quote Originally Posted by uspl View Post
    Things influencing the ability to back-drive or "free wheel":
    - Preload on the ball nut
    - Lead length
    - Weight of the moving assembly on the Z-axis
    - Inductance of the servo or stepper motor
    - Brakes/Springs designed to counteract gravity
    Personally, I'm taking a "build it and see" approach. I've got a fair bit of preload on my Z-axis ball nut and will probably go with a pretty beefy motor, so I may get away without having to add springs. Even if I have to add them, I prefer that given the other advantages I have (like going with a pre-built Parker Daedal actuator).
  1. X axis ballscrew replacement
    By gamila in forum Fadal
    Last Post: 06-06-2015, 12:00 AM
  2. ballscrew z axis
    By cxixer in forum Linear and Rotary Motion
    Last Post: 03-04-2009, 02:37 AM
  3. X3 Y-axis ballscrew
    By mikemill in forum Syil Products
    Last Post: 04-24-2008, 07:08 PM
  4. y-axis ballscrew binding
    By crazyman in forum Charter Oak Automation Support Forum
    Last Post: 07-05-2007, 07:55 PM
  5. VF0 X axis ballscrew
    By Geof in forum Haas Mills
    Last Post: 09-20-2006, 06:44 AM
