Hi Guys,
Built an 8x4 machine before christmas, had a gecko drive g540, replaced it with a more flexible system, PM542 drivers and Uniport V2 breakout board from zapp automation.. but now I have a problem
went to test it..
one axis is doing something odd though...
The motor moves very slightly in the opposite direction when it begins,
so if i tell it to move clockwise, it moves about an 1/8th of a turn anticlockwise before beginning its clockwise movement... could this be a driver problem? a board problem? a wiring problem? (it's wired the same as all the other axis which work fine...?) the step and dir wires and seperated from the motor wires..
Many Thanks
Andrew Bond
My build log is on here and needs updating I might do that now while I wait for the collective wisdom to kick in
I'll post a link
