Hello all,
Earlier this year I build one of the buildyourcnc book machines. I always took it at a learning experience, which it was. Also in the humid Virginia weather I have found that the book machine is not aging very well. The other day I was looking at ways to improve it and came to the conclusion that it would be better to build a new one from scratch.
The design I want to use is a joes 4x4. It seems the be the right size, and having the frame made of metal seems like a good idea in retrospect.
However I have some questions.
The big one is, how to cut the 8020 aluminum. As of this point almost everything I have is wood working tools. Can I get these peaces precut to the correct length? Or should I buy a new power tool for my small shop to cut these pieces.?
Finally, I am thinking of going with a rack an pinion drive. I have read that I will lose some accuracy. But is this really that big of a deal? I will be mostly cutting wood, with the occasional aluminum sheet. Right now my current book build is using a hardware store screw, so I imagine the rack and pinion will at least be better than what I am using now.
