586,094 active members*
4,060 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > Running Plasmacam on a newer PC
    Aug 2009
    24
    OK guys I am lookng to probably update the PC that is running my PlasmaCam DHCII. I have heard rumor that the plasmacam software does not play well with Newer windows versions, Is this true? I am really needing to start creating new parts in corel draw or similar software (solidworks or BendTech SM) but would prefer to have both softwares on one pc. My current PCam computer has windows 98 and the drivers for things like thumb drives and what not are not wanting to play nice together? thoughts suggestions?
    One more quick question is there much a a cut quality improvement to be had if I were to switch to a machine torch from the current hand torch?
    Mar 2011
    Please replace it with ordinry PC and work with EMC2.
    Oct 2006
    58
    Quote Originally Posted by rbmedic75 View Post
    I'm running Plasmacam 3.11 software on windows 7 pro 64 bit and, have no problems at all.
    I'm also running Design Edge on the same computer.
    Regards machine torch; I guess it depends on what cutter you're running.
    If it was a Hypertherm unit, 1000, 1250 or 1650, I'd recommend upgrading to a new retrofit Duramax machine torch, combined with a Snap 'n Cut magnetic breakaway mount.
    The beauty of the Snap 'n Cut system is, the torch remains square to the material at all times and, is also protected against breakage in case of a high speed tip up collision.
    If you're running a new Hypertherm 65 or 85, it's possible to run a machine torch with a dedicated control cable which, does away with having to splice wires internally as has to happen with the hand torch and, also allows rapid torch changeover from machine to hand cutting.
    Attached is the result you can expect....some 12mm plate I cut yesterday, Powermax 85 with 65amp consumables.
    Mick.
    Home Page
    Aug 2009
    24
    Thanks for the replies guys, sometimes it take me a while to get a minute or 2 to get back on here. Very glad to hear I can upgrade to a newer PC with hopefully no problems. I run the Hypermax 1000 and am definatley keeping an eye out for one of the new machine torches.
  1. In the Market for a newer Machine.
    By Toolz in forum EDM Discussion General Topics
    Last Post: 04-14-2010, 10:16 AM
  2. Newer computers missing something...
    By Bluegillman in forum HURCO
    Last Post: 03-05-2009, 03:26 AM
  3. Running newer software
    By Bushytails in forum FlashCut CNC
    Last Post: 11-03-2008, 01:15 AM
  4. Anyone with a 2000 or newer Arrow 1250C?
    By absoluteron in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-17-2008, 04:34 PM
  5. RS232 problem sending with newer PC
    By sys_man in forum Computers / Desktops / Networking
    Last Post: 06-11-2005, 02:36 AM
