586,075 active members*
3,922 visitors online*
IndustryArena Forum > CAM Software > Esprit > How to edit simulation machine models?
    Apr 2003
    1357
    I was provided a machine model that is too short. The spindles and turrets are in the correct location, but the machine base is too short. The sub-spindle sticks out the right side of the machine. I would like to edit the machine base, basically stretching it longer so that it looks realistic when showing our capabilities to prospective customers. How is this done? What reads the .esm files?
    Dan
    May 2011
    Quote Originally Posted by Dan B View Post
    Dan
    Since you were provided with the models for this machine, the .stl files are embedded in the .esm and are loaded in a temp folder. You can contact who ever gave you the .esm and see if they can give you the .stl for the base, or you can create one yourself and in your machine setup page under the assembly tab, you can point the machine base solid to a new .stl
    BG
    Apr 2003
    1357
    Thanks. I see the stl files now. I question the logic of Esprit placing them in a folder called "temp" as temp to me means temporary, or disposable. But at this point not much surprises me anymore.
    Dan
    Jun 2010
    81
    Since you have the machine model I would just smash the base that you want to make longer and then create a new solid for the base. Once you have the new solid, pick it, and save it as a .STL file in your Esprit folder.
    In the file you want to add the new STL base, go to Machine Setup, Machine Base, Solids, Pick the base solid to change it, then go find the new STL for the base. That should change the old base to the new one.
    Apr 2003
    1357
    Our reseller came through for us and fixed the model.
    Thanks for the replies,
    Dan
  1. Looking for 3D NC Machine models!!!
    By sdbradley11 in forum MetalWork Discussion
    Last Post: 05-09-2020, 03:39 PM
  2. SolidCam Machine Simulation
    By carbide_burner in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-13-2016, 06:34 AM
  3. mastercam x5 machine simulation
    By minhhungcali in forum Mastercam
    Last Post: 12-07-2010, 04:15 AM
  4. Rotary and Machine Simulation
    By coykiesaol in forum Mastercam
    Last Post: 11-17-2010, 01:47 AM
  5. Machine simulation files
    By maparkopo in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-16-2010, 08:54 AM
