586,217 active members*
2,977 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Routech Record 130 w/ NUM Controller Help
    Nov 2010
    Does anyone know the proper procedure for calibrating the router to the boring head? I have a setup manual for a morbidelli, but it seems to vary from the record.I'd give a first born for a printed manual. I can get either to machine accurately in the X,Y,and Z axis, but not both together. Any help would be appreciated. I have spoken to SCM, But the instructions kinda vary with the tech and the last set of directions doesn't seem to work. I can change the accuracy bu manipulating the required axis in the axis config file, but I thought the Pheads file was for the router, at least that's where for the Morbidelli k2.
    Thanks for any help,
    Dave
    Feb 2006
    14
    Hi dnormand25
    just look at your post today.... I have a RECORD-120 and MORBIDELLI A504K
    Find a file 8090.XPI and make a backup, you can modify the positions to calibrate the head
    Jan 2017
    24
    Re: Routech Record 130 w/ NUM Controller Help
    Quote Originally Posted by Baldo View Post
    Hi dnormand25
    Baldo, do you still have your Record 120? I have just aquired a 120 and have little to no documentation. Hoping you might be able to help
  1. help configuration SCM RECORD 220 ROUTECH
    By MaxPowa10 in forum Controller & Computer Solutions
    Last Post: 05-28-2021, 08:06 PM
  2. problem with cnc scm routech record 220 with num 1040 controller
    By mahamaha in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-27-2016, 05:10 PM
  3. Xilog Plus - Aspire - Routech Record 132
    By Rampage Dave in forum WoodWorking Topics
    Last Post: 10-23-2010, 10:14 PM
  4. Routech Chronos with NUM controller manuals
    By indybiker in forum CNC Machining Centers
    Last Post: 06-30-2009, 01:01 PM
