Who wants to help make it reality?
Installing the Tormach ATC « Milling Around
http://www.tormach.com/document_libr...S32279_ATC.pdf
Looks doable to me, need to make a bracket to allow proper positioning on the Mikini, need the right pinouts on the machine side (likely a second parallel port or a SmoothStepper), then "hopefully" can integrate the screen/code from the Tormach MACH3 in to standard MACH3 (this may prove to be the hardest part if the code is "locked down" in some way..).
