586,058 active members*
4,270 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Spindle calibration with Mach, VFD, and a G540
Results 1 to 6 of 6
    Jan 2007
    723
    Question Spindle calibration with Mach, VFD, and a G540
    Oh Boy!
    I was so exited to see my Chinese spindle and huanyang VFD controlled by mach! I have a few issues with the setup and I'm hoping you guys can help!
    The first problem i am encountering is when I start the the spindle it speeds up to 14000 when I specify 11000 RPM. I hit the reset button and it slows down closer to 11000. Mach shows 11000, but the VFD reads about 14000 How can I get it to start to the correct speed automatically without hitting the reset button?
    Next, the slowest speed mach is running the spindle at is 6836 RPM. The VFD is set for the slowest being 6000 RPM. What is going on here?
    The last problem is probably linked to the other two. The RPM reading in mach is proportionally not correct. The spindle is about 384 RPM fast at its slowest setting. At the high end, 24000 RPM, the vfd and mach are both correct.
    How do I correct the settings to calibrate mach to the vfd or the vfd to mach?
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Try adjusting your pulley speeds.
    Jan 2007
    723
    Yeah, that was the first thing I did but it did not solve the problems.
    May 2010
    I have the same issue with you Pplug. Have you figured out how to resolve this issue? Thanks in advance.
    Nov 2009
    4415
    Did you calibrate off of the motors spindle rpm first, then account for the pulleys?
    Jan 2007
    723
    Yes I did. Unfortunately, it doesn't matter. Mach is sending all kinds of different speeds. One job will run at a set 15000 rpm then the next job the speeds in the code are set the same and Mach changes the speed to something slower. It's a very weird problem.
    I ended up calibrating my settings for 15k and tweak it after to get something close to the one I need. It sux but I don't have modbus on the vfd.
  1. Cheap and easy spindle index sensor for G540 and Mach 3
    By grizzlymog in forum Gecko Drives
    Last Post: 06-10-2012, 01:16 AM
  2. Gecko G540 and Mach 3 Spindle control
    By rwskinner in forum Vertical Mill, Lathe Project Log
    Last Post: 10-24-2010, 10:58 PM
  3. Spindle Calibration. Denford Orac. Mach 3.
    By joetully1009 in forum Mach Lathe
    Last Post: 05-19-2010, 11:35 PM
  4. Replies: 2
    Last Post: 03-31-2010, 01:58 PM
  5. Mach 2 Axis calibration
    By mikie in forum Mach Software (ArtSoft software)
    Last Post: 08-17-2005, 01:19 PM
