586,108 active members*
3,321 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Need some help with controllers
    May 2011
    Hey, i recently purchased a shop droid cnc gantry setup and im now having issues with how to make it move. I chose the motor and controller setup i found on ebay. Just had a few questions on which setup and what the difference was really.
    Nema 23 Stepper Motor 287oz-in & 3 Axis Board CNC Kit - eBay (item 130500888053 end time May-22-11 02:29:18 PDT)
    I was told that setup would get me up and running and i wouldn't need anything other than wire some fuses and a computer to get my machine up and running, but then i found this and was curious what these extra boards are for and if i really need them:
    3 axis Nema23 stepper motor 287oz-in CNC controller kit - eBay (item 130513611138 end time May-26-11 20:21:43 PDT)
    The machine will be setup to make flanges and molds for carbon fiber work and other misc little tasks. I know ill need a 4 axis setup those links are just for reference.
    Thanks!
    Jan 2010
    2141
    The first set has the parallel port breakout board built in to the 3-axis driver board.
    The second set has a separate parallel port breakout board, and a separate driver for each axis.
    There are pros and cons for each approach, and the individual components may also have their own pros and cons.
    Dec 2007
    341
    The first would require less wiring on your part ,and in your case being new to this, it would be a better option less mistakes to be made and less chance of noise in your system. Hope this helps somewhat with your choice.
    May 2011
    Quote Originally Posted by woffler View Post
    Thanks guys. I'll be ordered my motors this week and when the last of the rails arrive ill post pictures of the completed setup.:rainfro:
    May 2011
  1. CNC Controllers
    By dolphin2010 in forum Want To Buy...Need help!
    Last Post: 07-26-2010, 12:49 PM
  2. Controllers
    By Russell@Iscar in forum Fanuc
    Last Post: 08-21-2008, 02:03 PM
  3. Old Controllers
    By Lbase in forum Fanuc
    Last Post: 05-21-2008, 01:50 PM
  4. use for controllers
    By don_harby in forum Fanuc
    Last Post: 03-02-2006, 03:14 PM
  5. Controllers ?
    By Ken_Shea in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 05:51 PM
