Working on my plasma table again. Frame work done, X axis done via ballscrew.
Not sure how I want to do the other axis.
I have a rack/pinion mounted on both sides, with the teeth facing down (idea is so dirt doesn't fall into teeth).
On the gantry I have a driveline that runs to both sides, servo mounted on one side driving that shaft. Output of that shaft obvioulsy needs to transmit power to rack (well pinion). Driveline Shaft is about 5-6" above the rack.
At first I had a swing arm setup with a spring pulling up on it to force pinion on to the rack. It was rather sloopy and I just didn't like it.
Need some ideas, either spring loaded or not. Pictures are even better. I may try to get some pics myself tonight.
Ready to move forward on this but after a few days not sure how.
Found one picture close to how mine is setup, but since I have the driveline to prevent racking of gantry I can't mount motor directly onto rack as it is here.
