586,077 active members*
3,712 visitors online*
    Dec 2009
    953
    FANUC ROBODRILL
    HI
    i have a fanuc robodril alfaiT14 and form yesterday night my spindle orinetation is wrong and is away with 1 theet and when is performing the tool change is not ok.
    i need a procedure to put back the spindle in the same position as is the tool in magazine.
    i tryed to adjust with parameter 4077 but after that it goes with alarm 250 spindle abnormal.
    i know is a simple procedure and pls if someone met this problem i will apreciate the help.
    Dec 2009
    953
    solved
    look in diagnose on 445 parameter for reading the new position of the spindle and than put that value in the parameter 4077 and 4073.
    Nov 2003
    98
    Glad you got it working. If I recall you have to do both 4077 and 4073. One is orientation with M19 and other is orientation during tool change.
  1. fanuc robodrill
    By gergelb in forum Fanuc
    Last Post: 12-19-2018, 04:18 PM
  2. Fanuc robodrill 16i-M 3d arc
    By TomL21 in forum Fanuc
    Last Post: 01-24-2011, 02:48 PM
  3. Fanuc Robodrill t14-ial
    By Mikko K in forum Fanuc
    Last Post: 03-03-2010, 11:06 AM
  4. FANUC ROBODRILL NEED HELP
    By WJ MARK in forum Fanuc
    Last Post: 01-01-2010, 09:31 AM
  5. Fanuc Robodrill
    By gregfull in forum Uncategorised MetalWorking Machines
    Last Post: 02-26-2007, 02:25 AM
