Three days ago my mill and lathe arrived during some heavy rain so I just shoved them in the already packed garage and over the last 2 days have started uncrating and tear down for the move to the basement.
The lathe being closest to the door is the first to get uncrated and torn down for the move. (it's also the lightest) The first thing I noticed was that the cross slide ways looked to have casting sand in them so I decided to take it down to the component level instead of moving the apron as one whole assembled piece. I was totally shocked today when I took the apron off the bed at what was underneath. The way for the bed on the apron is so bad that it would probably double as a crude file. It looks like it was never touched after casting. The top of the apron where I thought was casting sand was the actual casting. Both these surfaces are way surfaces. One being the actual lathe bed. I also have enough iron in the cross feed gear box to make parts out of. I just found this today and will be contacting Matt and QMT on monday to get this resolved. I'm very let down to say the least. Also the rear apron gib was barely touched with the surfacer. The rest of the lathe so far is in decent order, or what you would expect from a Chinese machine. Their is already a few parts I want to make to replace poorly designed and machined parts but I need the lathe operational to make them.
Edit: I'm not saying anything bad about QMT here. This was an overlooked piece at the factory and just want others to see it so they could check theirs out to see if they might have the same issue. I'm happy with the rest of the lathe so far.
