586,061 active members*
4,574 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Why does the chop saw fence have a v-shape?
Results 1 to 9 of 9
    Mar 2010
    36
    This might be a dumb question...
    Someone gave me a Makita chop saw LS1030. The fence is a one-piece. I'd be fine with that, but it has a v-shape to it. So, I can only adjust the fence to cut square long pieces or square short pieces. I cannot cut both without moving the fence or adjusting the angle.
    I plan to take the fence out and cut the middle section of the fence out. I'll then have a two piece fence where I can set them both in a straight line and square to the blade.
    What's the v-shape for???
    Thanks!
    Apr 2009
    5516
    Quote Originally Posted by Plugger View Post
    Thanks!
    Hard to understand what you mean? But usually the fence has angles for blade clearance when cutting a miter "on the flat", or a compound miter.
    Mar 2010
    36
    Here are some TOP VIEW sketches.
    This how I would set it up for cutting a long piece of wood. Note the gap between the wood and the fence since the fence is v-shaped. The u-shaped part of the fence goes behind the blade and is not cut. Then, when I use the same setup to cut a short block of wood the end will have an angle on it. Why do they put a v-shape on the fence? It's not bent. It's a casting in perfect condition.
    Thanks!
    Apr 2009
    5516
    Thanks!
    No that's a defect in the casting. They supposedly mill the face flat but I don't know why that happens. I 've used an auxiliary fence that's screwed on using the holes on the aluminum fence. Place a straight board long enough and screw it in using the holes Omost fences do). Use shims if there are gaps. Get the blade adjusted for a sqiare cut, and cut through the wood.
    If we just need to crosscut, we would actually make an auxiliary table, L-shaped, to sit on top of the chopsaw table. Just have to make sure you don't go through, or if it a sliding compound saw, set the depth so it doesn't cut through.
    Aug 2008
    409
    If your fence really is bent like that there is something not right. Can you take a picture?
    If your board does not touch in the center it will be dangerous to cut as it will want to grab the blade. No cuts made on that fence will be square.
    Something does not sound right.
    Apr 2009
    5516
    Quote Originally Posted by Phife View Post
    Yes the blade will be pinched by the wood as it's being cut...
    May 2007
    767
    Simple solution IMO is to remove the fence and make a pair of hardwood cheeks fitted with c/s bolts with nylock nuts and double coil washers. Then shoot the face flat and square with a shooting plane either machine or hand. Refit an check the new wooden fence face is both square (upright) to the table and the surfaces are perfectly in line. I have a Makita and it also has the fence faces 'v' shaped as in your sketch. This is a tad easier to do than the tip from louieatenza
    I use mine for cutting ex skip floor-boards for fire wood! Not precision work but it would bind on the blade if used without the cheeks.
    Regards - Pat
    Jun 2010
    It’s not that uncommon to be that way or for that to happen. I have 2 Bosh chop saws with the same problem. An auxiliary table with shims as posted before is a good fix.
    Mar 2010
    36
    Thanks everyone!
    Thanks everyone!
    I see that I am not the only one having this problem.
    Since the condition of the fence looks perfect, I originally thought it might be made that way for some trade-specific job.
    Maybe they didn't stress releive the metal or something, and over time, it "warped". I don't really know.
    In any case, I will either cut it into two or make my own one piece. It does seem easiest for me to just cut it into two with a hack saw and touch the end to a grinder to smooth it.
    Thanks again for the good ideas and feedback!
    ps - No pictures.... I don't have a camera right now. Sorry!
  1. Metal Cutting Chop Saw vs Abrasive Chop Saw
    By diarmaid in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-10-2024, 04:17 PM
  2. Opinions: wood chop-saw to metal chop-saw duty
    By soundmotor in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2009, 07:59 PM
  3. best basic chop saw
    By nc9933 in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2008, 09:10 PM
  4. Need a saw to cut material, Band or Chop?
    By mgb1974 in forum Community Club House
    Last Post: 07-30-2008, 05:22 AM
  5. Replies: 5
    Last Post: 03-24-2007, 03:40 PM
