Hi guys,
Because of a broken line in the central lubrication system, the ball screw on the X axis has been without lube for a while. I do not know exactly how long but I noticed it because the X movement has become more noisy over the last week. There seems to be no damage because the axis is easily moved by hand. I repaired the line but there is still no lube coming through. The return flow valve is in the right direction though. I suspect the line has clogged during the dry time.
Does someone know a way to de-clog the line without the need to take apart my machine? Is there an agent that dissolves the greasy oil in the line without damaging the ball screw?
The ball screw will become more quiet when it is lubed properly right?
