Hi to all,
I need some help with setting up my mach3 configuration. I read almost every post that I could find on the internet but still can figure it out what's going on. The problem is that when I jog the machine it moves smooth and fast but when I load g code for profiling the motion slows down and motors makes a lot of harsh noise. I tried different motor tuning configuration and also many other settings but no luck at all. Some specifications of my setup:
PC:
Processor: Pentium 4 - 3.2Ghz
Ram memory: 2 Gb DDR2
Cnc
Controller: Tb6560 board
X axis: Nema 34 step motor, 8 micro steps, 16mm screw, pitch 10 mm
Y axis: Nema 23 step motor, 8 micro steps, 16mm screw, pitch 10 mm
Z axis: Nema 23 step motor, 8 micro steps, 16mm screw, pitch 5 mm
Here you is the link to short video where you can see and hear what's going on with the machine when jog and when start working on the profile cut.
[nomedia="http://www.youtube.com/watch?v=uwzfqMPyA2Y"]YouTube - ‪cnc‬‏[/nomedia]
I also made screen shots of my mach3 configuration.
