586,416 active members*
2,937 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > roughing and finish pass
    May 2006
    94
    I'm selecting the bottom face of a pocket. Choosing to rough with a 1/2" EM. Now, I need to go back with a 1/4" EM to clean up the corners, and where webs still exist between areas to small for the larger end mill.
    Gibbs cam is new to us, I can knock it out on Pro/NC no problem. I'm working late into the night on this, so any help would be appreciated.
    Aug 2009
    235
    Do another roughing op, but check "use stock" and "material only". Its at the bottom of the roughing prosses window.
  1. How to chamfer/finish pass
    By wildwhl in forum CamBam
    Last Post: 10-09-2012, 01:49 PM
  2. what bit to use on roughing pass in cherry?
    By groomden in forum WoodWorking Topics
    Last Post: 10-07-2009, 08:22 PM
  3. Finish Cutting pass.
    By Greg Maxwell in forum Mastercam
    Last Post: 11-21-2007, 06:10 PM
  4. Replies: 13
    Last Post: 01-10-2006, 03:22 PM
  5. Empty Roughing pass
    By new2cnc in forum Mastercam
    Last Post: 05-28-2005, 02:31 PM
