586,525 active members*
3,250 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Alphacam Router Z value issue
Results 1 to 2 of 2
    Apr 2011
    Greetings everyone,
    Im just at work here trying to program a job using Alphacam. Im having a problem with the Z value. Basically, on the Alphacam model the material is set at 12mm(My Z is set to 0 at the bottom of the material). My fixture is 24.2mm. The final thickness of the job is supposed to come out at 11.7mm. When I output the NC code I am only asked for the fixture height & not the material thickness (presumabley because its set on the model), I enter my 24.2 & in the NC code the E3 value comes out at 36.2(Part + Fixture height). All good & well so far. However, when the operator runs the program its coming out exactly 12mm above the 11.7mm that I want. When the operator changes the Z himself on the machine back to 24.2, the job is coming out the way we want it. Any advice on whats going wrong on the programming side would be greatly appreciated.
    May 2004
    4519
    When you set "Z" levels, are you setting Absolute or Incremental?
  1. Alphacam???
    By tomvaughan in forum Commercial CNC Wood Routers
    Last Post: 11-23-2011, 06:27 PM
  2. alphacam advanced router help needed
    By kaighn80 in forum Uncategorised CAD Discussion
    Last Post: 05-17-2011, 06:21 PM
  3. Can alphacam run a techno isel gantry router?
    By Nibbs in forum Screen Layouts, Post Processors & Misc
    Last Post: 03-30-2009, 06:25 PM
  4. alphacam 3d
    By shab_108 in forum Uncategorised CAM Discussion
    Last Post: 11-28-2008, 08:23 AM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
